Help Computer went crazy!
Old Jan 22, 2020 | 12:30 AM
Adrian Torin's Avatar
Adrian Torin
Hello guys, so the problem starts when i leave my interior light on a few hours and my battery was dead, after that i ask for help to a friend to recharge my battery with his car. My car start and everything was ok, until the next morning. My cant wont surpass 2k rpm and the brakes lights still on, after I turn off my car. A friend suggest me to disconnect the battery for a few minutes and connected again to reset everything, but now is worst because keep the same problems and in addition my windows come down completely wen i open the door, And the car can start with out press the brake. Its went crazy, any suggestions?. What i need to do to fix this problem?
Old Jan 22, 2020 | 05:00 AM
Surfnazi's Avatar
Surfnazi
Unplug the battery overnight and discharge the plugs
Old Jan 22, 2020 | 08:27 AM
Adrian Torin
I leave it disconnected last night, lets see what happen
Old Jan 22, 2020 | 10:28 AM
ILM-NC G37S's Avatar
ILM-NC G37S
The interior "map" light should not have severely discharged your battery after being left on for a few hours. That tiny bulb does not draw that much current.
How old is your battery? If it 2-3 years old, or older, you should have it tested to make sure it is not going bad. At the very least you should get it fully charged before your next trip. Once the battery starts getting weak, all sorts of oddities happen with these cars...
Old Jan 22, 2020 | 11:10 AM
Adrian Torin
I take the car to an advance auto part to scan it, and the como that appears is
P2A03 a damage sensor, Im getting a new one, but i was reading that maybe my catt is damage and thats why my cant wont accelerate ☹️
Old Jan 22, 2020 | 11:35 AM
ILM-NC G37S
P2A03 refers to a fault with the Bank 2 (driver side) air/fuel ratio (A/F) sensor:
Separate issue from a dead battery. Could be anything from a bad sensor to a air leak. I doubt a clogged/damaged catalytic converter would set this code but I can not say for certain. What makes you say the "cat" is bad?
Charge your battery, reset everything, and go from there. If the code sets again, then you know where to start.
Old Jan 22, 2020 | 04:00 PM
Adrian Torin
Problem solved!
Problem solved guys. turned out to be a fuse giving problems. Thanks God i dont use the sensor and i was able to returned 🙏🏼🤣 and thanks every one for the tips and everything was helpfull.
kdube
General Tech Questions
Feb 4, 2019 08:37 AM
Gthangftw
Dec 17, 2015 08:09 AM
michg37
Apr 13, 2015 04:03 PM
kOrE
Jul 30, 2014 09:55 PM
Amon_Ra
Nov 9, 2011 02:54 PM
