Car not starting after being unused
Old Oct 9, 2018 | 11:53 AM
itshere's Avatar
itshere
Hi all -
Had this a few times already but if I don't drive my car for over a week or 2 - I cant start it. Its not the battery because I recently changed it. As soon as I connect the booster cables it starts immediately and runs perfectly, then I can turn off and on no problem. Is it weather related? even though it hasn't been that cold in Toronto the last 2 weeks. Gas was about a quarter full.
** not sure if its somehow related but my trunk lights doesn't work anymore either - I replaced the bulbs but it seems like there's a different issue.
any help is appreciated thanks!
Old Oct 9, 2018 | 12:57 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Does the car crank at all? I'd check the battery voltage when you're having the issue. What's the voltage with the car running at idle, running at ~2K rpm?
Old Oct 10, 2018 | 09:00 AM
Bostonreefer's Avatar
Bostonreefer
How cheap did you go on the new battery. What your describing points to a battery.
Old Oct 10, 2018 | 12:14 PM
telcoman's Avatar
telcoman
Originally Posted by itshere
Hi all -
Use a battery hydrometer to measure the specific gravity in each cell
Any cell not accepting a full charge is the cause of your problem. Replace the battery
Just because you replaced the battery doesn't mean all the cells are good.
Telcoman
Old Oct 11, 2018 | 10:11 AM
itshere's Avatar
itshere
yea ~ 2K RPM if not a little less.
Old Oct 11, 2018 | 05:09 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^To whom are you replying? Please rephrase your statement.
Old Oct 12, 2018 | 12:18 AM
Epiphany's Avatar
Epiphany
It's definitely the battery. Either it's not holding a charge, or the car is draining the charge. Got a remote starter by chance?
Old Oct 12, 2018 | 02:14 AM
crookncastle's Avatar
crookncastle
you either got a parasitic draw or that battery you go is a piece of cr ap. you stated with a battery jumper/booster the car starts up so now you would need to either recharge or replace the battery then check how many milliamps of current is being drawn on the battery. if there is little of no draw, 50 milliamps or less, ditch the battery and get a new one.
Old Oct 12, 2018 | 01:48 PM
itshere's Avatar
itshere
I do have a remote charger (after market one)
Old Oct 12, 2018 | 01:55 PM
itshere's Avatar
itshere
replied to your question.
Old Oct 12, 2018 | 04:47 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Does the car crank at all - answer: yes/no
Voltage when the car is running at idle - answer: Some number with a V at the end
Voltage with the car running at ~2Krpm - answer: Some number with a V at the end
Your answer above is meaningless. Post #7 is asking about a remote starter. What is a remote charger?? Remember, GIGO...
Old Oct 13, 2018 | 08:17 PM
Epiphany's Avatar
Epiphany
Either that's draining your battery or your battery is shot. Figure out which and problem solved.
Randy Johnson
Jun 29, 2015 10:47 AM
Mr.Lewis
Oct 9, 2011 09:13 PM
g37cam
Jan 30, 2011 12:50 AM
EnfinitI
31
Dec 15, 2010 12:40 PM
