Fluids
Old Jul 27, 2018 | 06:11 PM
GeezerB's Avatar
GeezerB
Fluids
Just got car back from the dealer (oil change & free inspection). They are recommending Brake flush for $166 & Power steering flush for $186.
I have 40k miles on my car. Are these really necessary at this point? Are these prices way high? I don't have the ability to do it myself even though it is probably easy.
Advice?
Old Jul 27, 2018 | 06:50 PM
slartibartfast's Avatar
slartibartfast
Brake fluid should be changed every two to three years. Power steering fluid should be changed per the owner's manual unless you spend a lot of time autocrossing, then every couple of years.
Old Jul 27, 2018 | 07:09 PM
GeezerB's Avatar
GeezerB
I just looked throughout the manual & I can't find an interval chart. Am I blind?
Old Jul 28, 2018 | 09:56 AM
JSolo's Avatar
JSolo
Just say no!!!!!
There's a separate maintenance guide.
https://owners.infinitiusa.com/conte...ance-guide.pdf
Old Jul 31, 2018 | 08:27 PM
ragnar's Avatar
ragnar
No and yes, I would not think it is necessary with that low of mileage. That said, I'm glad the '08 I bought recently had these done at 44K miles, by previous owner. Yes, prices are high. I have the receipt for where mine was done. Harper Infiniti in Knoxville, TN. Brake flush was $107, power steering flush was $80. This was done July 2017
Old Jul 31, 2018 | 09:21 PM
yoda466's Avatar
yoda466
I recently paid $100 for brake fluid change at a Nissan dealer. Nissan fluid.
Old Jul 31, 2018 | 10:16 PM
saywat?'s Avatar
saywat?
i use schedule 2. schedule 1 lists the reasons why you would go with that frequent of a schedule. and im lazy and aint trying to change things that often lol. i have better things to do with my time like watch impractical jokers all day
Old Aug 1, 2018 | 02:09 AM
Infin88's Avatar
Infin88
I followed this video for power steering fluid:
edit: I put 2 flat cardboard pieces under my front tires when rotating the wheels while changing the fluid.
Old Aug 1, 2018 | 12:38 PM
telcoman's Avatar
telcoman
Advice?
Not necessary!
Do a brake flush as part of pad replacement and rotor turning
I traded in my 2012 G37S at 94444 miles and never had that done.
It is now the next owners problem
Telcoman
Old Aug 1, 2018 | 01:20 PM
Baadnewsburr's Avatar
Baadnewsburr
Advice?
the prices ragnar posted are what you should expect to pay on average and re in line with dealership prices where I am. The quote on the brake flush is kind of high, but the PS flush is just a complete ripoff...the brake flush requires more work and potentially more fluid at least and should be done on a lift with the wheels off.... the PS steering flush takes about 15 minutes in a driveway and barely takes a quart of fluid, no special equipment required (unless you count a turkey baster) or disassembly of other components, you don't even have to jack up the car.,...both jobs can be done by any competent mechanic if you're limited on dealer options also try a Nissan dealership...they will probably do it for less.
Necessity for the PS flush is not likley at your mileage,
the Brake fluid is probably necessary at your mileage but may be dictated by time as well. ie. if yours is over 3 years old and it has never been changed you should probably do it.
Brooklynstar23
48
Sep 25, 2011 02:04 PM
clutch5
Feb 23, 2011 01:40 PM
consultant1027
General Tech Questions
Oct 9, 2010 03:27 PM
Retromoe
Jan 25, 2009 06:38 PM
