Life of oem brake pads
Old Apr 12, 2018 | 05:04 PM
misc's Avatar
misc
About how long is the life of the oem pads? I'm at 40k and as far as I know they haven't been changed before, and they seem ok....however I think i'll be changing them out soon for some with a little more bite.
Old Apr 12, 2018 | 06:45 PM
Tim30250's Avatar
Tim30250
Oddly, my rears needed replacement first @ ~45K miles. Just did my fronts late last year @ 70K.
Old Apr 13, 2018 | 11:00 AM
slartibartfast's Avatar
slartibartfast
Quite variable, depends upon your driving style. I changed mine at 48k miles because of two track events.
Old Jul 27, 2018 | 09:41 PM
ross7778's Avatar
ross7778
My rears didn't last long. 35K? I'm currently at 57K with original fronts. The dealer told me the rears are thinner than the fronts and will need to be replaced more often.
Old Jul 27, 2018 | 10:29 PM
crookncastle's Avatar
crookncastle
nissan uses hitachi brake pads when the vehicle came off the assembly line. those things are solid and can go quite a while before needing to be replaced. like others have stated the rears will need to be replaced sooner than the fronts. in addition if you don't brake like a bat out of hell i think you can probably hit 60k on the front pads with no problem.
Old Jul 28, 2018 | 08:36 AM
telcoman's Avatar
telcoman
On my previous 06 G35 6 speed manual the factory OEM pads were replaced and rotors turned by the dealer at 84948 miles
Those pad were still on the vehicle when I traded it in at 171796 miles for my 2012 G37S 6 speed.
When I traded in my 2012 G37S last February it still had the original factory OEM pads at 94444 miles
At one of my recent oil changes at the dealer as part of their vehicle inspection prior to trade in I requested the thickness of my brake pads and they still had 8mm left on them
When driving a manual I downshift a lot using the engine and transmission to do a lot of the vehicle braking which vastly extends the life of brake pads.
Telcoman
Old Jul 28, 2018 | 02:14 PM
hobbs's Avatar
hobbs
Originally Posted by telcoman
When driving a manual I downshift a lot using the engine and transmission to do a lot of the vehicle braking which vastly extends the life of brake pads.Telcoman
Brakes are cheaper than clutches.
Calg37USMC
Aug 22, 2020 03:10 PM
ANMVQ
24
Jul 3, 2018 01:20 PM
jrbhorn
Apr 26, 2018 01:37 PM
