Engine Dying
Old Apr 7, 2018 | 10:02 PM
toddvb's Avatar
toddvb
Engine Dying
This is odd, but I'm curious as to why.
Last Friday I parked in my doctor's office lot and when I came out 30 minutes later my car started and then died when it went to idle. It did this twice, but the third time I hit start I gave it a little gas after it started and everything after was fine. Fine for two days and then I had to go back on Monday and it did the same thing, although I recognized the situation and gave it some gas on the second startup. Startups have been fine for the last five days. I parked a few spots down the second time from the first, but in the same general area. No other problems with the car (other than the passenger door lock not working. Driver side had the same problem and was fixed last year.). Dealership just serviced it a three weeks ago. 2009 G37 X.
Any ideas?
Old Apr 7, 2018 | 10:12 PM
slartibartfast's Avatar
slartibartfast
Throttle relearn? Dirty MAFs?
Old Apr 7, 2018 | 11:46 PM
Stachuu's Avatar
Stachuu
Sounds like typical issue with dirty throttle body, had this happen 2 years ago till I cleaned both side, been on top of this every summer since.
Old Apr 8, 2018 | 09:26 AM
SonicVQ's Avatar
SonicVQ
Stachuu is correct.
Dirty throttle bodies will cause the car to start and die.
If you give it a little gas, the car will start fine, since that opens up the throttle just enough to prevent it from stalling.
Clean them or get them cleaned.
Old Apr 8, 2018 | 10:04 PM
toddvb's Avatar
toddvb
Thanks. I'll keep an eye on it and get that taken care of if this starts to occur more frequently.
Old Apr 11, 2018 | 11:00 AM
Джон's Avatar
Джон
Happened to me too. Dirty throttle bodies
Lije Baley
Mar 13, 2014 02:56 PM
Infiniti7
Feb 24, 2010 12:39 AM
frcefed
12
Apr 22, 2009 11:28 AM
Khalid-NS
Oct 8, 2008 01:29 AM
