2008 g37s A/T acting up some sorta glitch?
Old Mar 24, 2018 | 10:12 AM
Alex458116's Avatar
Alex458116
Angry 2008 g37s A/T acting up some sorta glitch?
2008 Infiniti g37. I turned my car on . many dash lights turned on (Slip, vdc off, AFS, etc..) headlights begin to flicker and then stay on (headlight switch is in the OFF position) I noticed radiator fan would turn on and off along with the headlight. and now my car wont shut off. after pushing the "Push-Start" button several times. also RPM and temperature gauges are unresponsive and also flicker up and down randomly. I managed to shut the engine off by pulling the MAF sensors. but it wont get off ACC mode.
Old Mar 24, 2018 | 01:56 PM
beefychicken's Avatar
beefychicken
Water intrusion of the BCM is my first thought. That is a common point for most of the things you listed that are acting up. Maybe the sunroof drain failed and water is leaking on the BCM? Or, was it in a flood recently or salvaged from a flood? (just reaching for ideas, but would really look at the BCM to see what is going on)
Old Mar 24, 2018 | 03:28 PM
Bostonreefer's Avatar
Bostonreefer
that sucks and is crazy scary to not be able to turn off an engine. my g is my first pts car. in an emergency situation to turn engine off rapidly press pts 3 times or hold in for more than 2 sec.
i agree with above sounds like water/electrical
good luck
marklong
May 29, 2015 11:07 PM
cmyva
Aug 5, 2014 12:53 PM
4rnr
Aug 12, 2013 11:48 PM
User 111021
Aug 4, 2013 09:04 AM
Fragnetic
Buying & Leasing
16
May 13, 2009 04:18 PM
