Air in cooling system or..??
Old Jun 14, 2018 | 01:54 PM
rudeboyride's Avatar
rudeboyride
ok cool .. Will try all!! Thanks
Old Jun 14, 2018 | 04:45 PM
slartibartfast's Avatar
slartibartfast
If you have cooking thermometer, you can test the thermostat in a pot of water. If it's open by 180 degrees F, it's good.
Old Jun 14, 2018 | 07:28 PM
Surfnazi's Avatar
Surfnazi
Once you get problem solved and are ready to add fresh radiator fluid dont forget to add a bottle of water wetter
Old Jun 14, 2018 | 11:53 PM
Ricio1991's Avatar
Ricio1991
Originally Posted by rudeboyride
So i bled the system with the funnel and it seem to be a bit better. was ok for a few days then CEL again. Same p0128. I replace the original thermostat and replaced it with the aftermarket mishimoto thermostat but still having the same problem. really need help!!!
I have a Mishimoto thermostat and it throws a CEL for opening up at a lower temp (150) vs 174 so the CEL if it indiacates thermostat opening at lower temp is normal since the thermostat is opening sooner than it should
Old Nov 14, 2018 | 03:31 PM
rudeboyride
@Rico1991 So I am still having the CEL issue. Your having the same? did you test to make sure its working ?
