Help Power steering fluid drain+fill
Old Apr 19, 2015 | 04:09 PM
velocity1689's Avatar
velocity1689
Kind of silly question...but how do I get the fluid out of the power steering reservoir? I am using a plastic turkey baster, but it feels like it is hitting a wall inside the reservoir.
Old Apr 19, 2015 | 08:07 PM
KENNEDY's Avatar
KENNEDY
What do you mean hitting a wall? Are you trying to remove more fluid than is in the resovoir?
Here's the procedure I used when I changed the PS fluid in one of my previous cars. The G should not be any different.
1. Empty as much fluid from the resovoir as possible. Its okay to leave some in there.
2. Refill the resovoir with new fluid. Tightly screw the cap back onto the PS resovoir.
3. Turn the steering wheel with the car on from lock to lock several times. This will circulate the new fluid in with the old fluid.
4. Repeat as many times as necessary until the fluid in the resovoir looks clean after turning the steering wheel. I think I remember having to do this like 8 times on my Mustang until the fluid looked relatively clean.
That's going to be the easiest way. I hope that helps.
Old Apr 19, 2015 | 08:24 PM
velocity1689
When I put the baster in, it seems to hit some kind of plastic wall about 1 inch in that's blocking it from going further.
Old Apr 19, 2015 | 09:47 PM
vqsmile's Avatar
vqsmile
I just used a short length of vinyl tubing slipped over the end of the baster to make an extension that I could drop down through the hole in the top of the reservoir.
Old Apr 19, 2015 | 11:50 PM
tech37's Avatar
tech37
Did you use the Nissan PSF or Transmission fluid as a replacement? Since the manual says either is fine...
Old Apr 19, 2015 | 11:52 PM
sLADe781's Avatar
sLADe781
Do you have the engine running when turning the steering wheel from lock to lock or just have the car on (but engine not running)?
Old Apr 20, 2015 | 12:05 AM
velocity1689
I got ATF (matic-s) from walmart.
vqsmile's Avatar
vqsmile
The engine has to be turning (running) to rotate the belt that turns the pump which circulates the fluid.
Old Apr 20, 2015 | 10:08 AM
tech37's Avatar
tech37
Hmmmm....just wondering if one was better than the other. The manual states Nissan PSF or Dexron VI...I thought Matic-S was different than Dexron VI...
Was trying to save some time and money but I might just get the PSF from the dealer and try to change as much as I can...
fuzzed
Aug 21, 2020 09:35 AM
vamarris
Dec 9, 2018 11:10 AM
MrRiv
Sep 29, 2015 04:59 PM
mikysee
Sep 28, 2015 11:18 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
