Transport Mode Switch
Old Nov 23, 2014 | 03:21 PM
CoolBreeze's Avatar
CoolBreeze
Replaced my battery and afterwards, the analog clock and homelink did not function.
The transport mode switch was in the in position. I did the wiper and turn signal switch in the down position for kicks to no avail.
Can the transport mode fuse switch come out easily without undo force, to be able to check the fuse? It did not seem to.
TIA
Old Nov 29, 2014 | 11:04 PM
TVPostSound's Avatar
TVPostSound
Transport mode is a German car thing.
Not with Infiniti.
Old Dec 2, 2014 | 05:00 PM
CoolBreeze's Avatar
CoolBreeze
I found the name transport mode switch name in this forum and some Mr. Fixit’s with alleged replies from Infiniti technicians.
After further research, I came up with the proper name of extended storage switch, which I did end up finding in the owner’s manual. This is the switch one should pull if the car will be sitting for a while, to minimize battery drain. Which comes down to RTOM – read the owner’s manual.
Pinching the switch with my fingers to remove did not work. I ended up using a couple of small needle noses. The fuse was blown. Replaced it, now everything is working.
Why it blew, I do not know. As far as I can tell, only the analog clock and home link are on the 10A fuse.
I did check for error codes in the “secret” diagnostic screen, and there was a code for a previous instance which is cleared or is now OK. I will have the dealer look into it further when I bring my car in for service in a few weeks.
vamarris
Dec 9, 2018 11:10 AM
Upscale Speed
Dec 26, 2015 08:45 AM
parkern
Oct 1, 2015 10:15 PM
MrRiv
Sep 29, 2015 04:59 PM
steven92
Sep 23, 2015 08:48 AM
