Recommend a AGM battery . . .
Old Sep 1, 2014 | 02:27 AM
hobbs's Avatar
hobbs
Besides a Optima Red Top. My experience with the Red Top on my wife's IS300 tells me that they are not the same quality they once were.
Old Sep 1, 2014 | 12:18 PM
duffster's Avatar
duffster
Optimas have been crap for a while. I just put in a Batteries Plus AGM, sealed so no water/corrosion issues. 3 or 4 year warranty, cant remember but they have 2 different types for the G37.
Old Sep 1, 2014 | 02:26 PM
hobbs's Avatar
hobbs
And the big question is . . .
Tips for getting it out and back in, as it looks like a PITA. Does the surrounding trim need to be removed?
Old Sep 1, 2014 | 07:03 PM
duffster's Avatar
duffster
That's easy. Remove the battery cover, then remove all the plastic push pins that hold that trim piece in place (use a small screw driver to pop up the center pin a bit then grab the outer piece with your fingers and pull straight up). If you have to remove the plastic cowl section I believe it comes out with 1 push pin hidden on the fender seam and a clip holding it to the drivers side section which is easy to see how it comes undone.
Old Sep 2, 2014 | 05:21 AM
Surfnazi's Avatar
Surfnazi
Well interstate and optima are same company. You'll get a bad battery from and manufacturer. Last redtop optima lasted 6 years cause car was sold with it.
rk325
Oct 13, 2015 01:51 PM
Jsmitty2002
Sep 29, 2015 07:55 PM
MrRiv
Sep 29, 2015 04:59 PM
xmajd92
South
Sep 28, 2015 07:22 PM
dedmanchan
Sep 24, 2015 11:25 PM
