Help Lighting issue
Old Sep 4, 2014 | 12:17 PM
Xenolith666's Avatar
Xenolith666
Lighting issue
So... I fuc.ked up. I was adjusting my city lights as one of the led's had come loose.. so in my infinite wisdom I took a piece of tin foil and put it around the light housing to get a snug connection. I figured low voltage, it wouldn't make a difference.. done the same thing with batteries and such. How wrong I was!
Anywho... as I put the light back in, there was a little pop and all the lights went off. The low beams, high beams, fogs, blinkers and tails still work.. but the city lights and side markers will not turn back on. I replaced the bulbs and still nothing. I checked all 3 fuse boxes and found no blown fuses.
So now I'm open to suggestions as what to do.. should I detach the battery and basically reset the car? Or just bite the bullet and take it to the ****in dealership since they can just plug a computer to it and figure out what it is instantly. Thanx
Old Sep 5, 2014 | 11:02 AM
Xenolith666
dealership it is then =P
Old Sep 5, 2014 | 11:40 AM
LOAF3's Avatar
LOAF3
Yup ^
Best to take it there before you mess around anymore.
Just explain the whole situation.
Manny735
Aug 14, 2017 09:25 AM
redlinernyc
Feb 29, 2016 11:06 PM
tomro99
Nov 17, 2015 02:08 AM
ZachThomas
Sep 3, 2015 01:40 PM
TVPostSound
General Tech Questions
Sep 2, 2015 04:09 PM
