Horn not working
Old Aug 22, 2014 | 01:11 AM
msonbolg37x's Avatar
msonbolg37x
Horn not working
my horn has been acting up. it would work for a while then it would stop working but it recently stopped working all together. i assumed that the horn was bad but i decided to try to clean it and give it a try. i cleaned it then hooked it up to a battery and it was working fine then i tried to put it back in the car but it still didn't work. can anyone help?
Old Aug 22, 2014 | 03:11 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Here's the manual:
http://www.nicoclub.com/FSM/G37/Sedan/2009/HRN.pdf
There are a couple relays, a couple fuses, a couple connectors, the spiral cable in the steering wheel, and a ground all involved. Intermittent operation is the hardest thing to trace but since you know the horn itself is good you should be able to trace back from there and hopefully find the fault.
Amaadkhan2k
Oct 4, 2024 01:20 PM
lobuzz311
Sep 15, 2015 10:09 AM
misc
Sep 11, 2015 03:53 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
New2Infinity
Sep 9, 2015 10:34 AM
