brand new 2013 G37: oil change advice for schedule 1 driving?
Old Jan 8, 2014 | 09:04 PM
heftylefty58's Avatar
heftylefty58
Question brand new 2013 G37: oil change advice for schedule 1 driving?
We just bought a brand new 2013 G37 sedan, and I'm seeking oil change advice.
Considering we primarily take short trips of less than 5 miles, I plan to follow the schedule 1 maintenance interval (ie, oil change every 3 months).
I came across this advice in "The DEFINITIVE oil thread":
For the first two oil changes, use conventional oil. After that, use full synthetic oil.
Curious to get any/all opinions regarding the above recommendation?
PS When we bought the car 2 weeks ago, my dealership said they would do my first oil change for 19.95...but I also found out they use a synthetic blend for all oil changes. Not sure why, but I found it surprising that the dealership would use a blend.
Old Jan 9, 2014 | 01:46 AM
hobbs's Avatar
hobbs
They use a blend because it's cheaper and they still get to use the word synthetic. Do the first oil change with M-1 EP 5-30 and repeat every six months while under warranty and then every 5,000 miles .
Old Jan 9, 2014 | 11:04 PM
heftylefty58
Thanks hobbs. Prior to our G37, we had a G35 for 5.5 years, and averaged 8,400 miles per year.
With our G37, I'm inferring it could take 6 months for us to cover 5,000 miles. If this happens, do you see any issues if we only change our oil (with M1 EP 5w-30) at a frequency of 2 times a year?
Old Jan 10, 2014 | 01:31 AM
hobbs's Avatar
hobbs
That should be no problem at all. My wife's 2003 IS300 gets about 8-10K per year and I change the oil every (12) months. Blackstone says the oil would go farther, but (12) months is enough.
The IS is much easier on oil than the G so every (6) months should be fine. See post #264 here; https://www.myg37.com/forums/engine-...ml#post3710567
Old Jan 10, 2014 | 03:25 PM
heftylefty58
Excellente, will do. Huge thanks for getting those tests done!
Forgot to ask:
Considering all our trips are short and that we don't rack up many miles per year, when do you recommend I do my first oil change? At 3 months? At 6 months?
Old Jan 10, 2014 | 05:16 PM
hobbs's Avatar
hobbs
I have always done the 1st oil change on a new car at 1,000 miles. Ignore the ones who say it is too early and the rings will not seat. If the rings are not seated by 500 miles, they probably never will seat.
Old Jan 17, 2014 | 03:37 PM
heftylefty58
I was thinking of stocking up on $50 of wix filters over at filter1.com; they carry the 51358 oil filter for $8.73 (and the 49362 engine air filter for $7.50). However, I'm wondering it's a good idea to run the wix 51358 oil filter for 6 months at a time?
Do you suggest I go with the "Mobil 1 M1-108 Extended Performance Oil Filter", instead? I noticed amazon currently has it for ~$13.
Or, if you recommend something other than the above 2 oil filters for my 2013 G37 Sedan, please share your thoughts. Thanks!
UPDATE: FWIW, I just compared RockAuto's prices to filter1's; RockAuto is even cheaper.
Old Jan 19, 2014 | 11:33 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
I've heard good things about the Wix filter, and IMO, I think oil changes should be done on a mileage basis rather than a time basis. I use full synthetic and change my oil every 5500-6000 miles. I just did an oil change today while installing my oil cooler and used a purolater PureOne PL14612, it's significantly larger than the OEM filter. Also filled it back up with Mobil 1 10W-30 full synthetic oil, 7 quarts with the cooler.
Old Dec 26, 2014 | 12:39 PM
Alexander072993's Avatar
Alexander072993
Okay so I've heard many mixed opinions about this. I just got my 2014 q60 (g37x) a couple months ago and have 2k miles on it so far. I just bought some RP 5w-30 full synthetic, and id like to switch to that at 3k or so. I'm positive I am running on Dino oil right now because the dealer I went to is cheap and even had the nerve to fill my car up with 89 fuel instead of 93 when I picked up for delivery. So my concern is will I be okay switching to synthetic at 3k or what???
Old Dec 29, 2014 | 01:48 PM
G37Xtreme's Avatar
G37Xtreme
I would do an oil change right now. Use dino oil and a new filter. Then change in another 3k miles with synthetic.
I think it's a good idea to change your first oil sooner than later. I can't comment on the notion of using dino oil for the first xxxx-miles either, but I know there's nothing wrong with using dino oil in 3k miles increments.
It's probably more important to get the fist oil change done sooner, so to avoid the argument of dino vs synthetic, do an oil change now with cheap oil.
timc00k
Sep 5, 2015 05:12 PM
Mattlorentzoe
Aug 21, 2015 05:09 PM
cellwoot
Aug 13, 2015 04:27 PM
zero260
Aug 12, 2015 10:02 AM
Ali K.
Aug 5, 2015 11:49 PM
