Window rolls down but doesn't roll up
Old Jul 27, 2012 | 06:36 PM
Silverfox08's Avatar
Silverfox08
Have a g 37s got it from an auction. Came with windows rolled down and taped up.., checked fuses and still no solution.. So I took door panel off. Disconected motor socket and directly SENT POWER to it. Problem solved. The only problem is I can't put my windows down, to enjoy The soung of my g ... Except am ready to go process of taking door panel off every time windows goes down.. Got mechanics telling me to get a new motor and window switch . Any help will be appreciated g fam
Old Jul 27, 2012 | 07:58 PM
frty9rsfn's Avatar
frty9rsfn
sounds like you already know the solution to this one...
Old Jul 27, 2012 | 08:05 PM
Rad_Slinger's Avatar
Rad_Slinger
never mind...read the op wrong
Old Jul 27, 2012 | 08:07 PM
Silverfox08
Dude been dealing with this for 2 weeks .. just need to get fixed
Old Jul 27, 2012 | 10:22 PM
advan37's Avatar
advan37
You just need to reset them, hold both of the window buttons up for a couple of seconds with the car on and it will reset .
Old Jul 27, 2012 | 10:41 PM
Silverfox08
tried that ,still no sucess
Old Jul 27, 2012 | 11:07 PM
advan37's Avatar
advan37
Hold the buttons couple of seconds (10s) down then hold them up for other 10s . Try it should work , unless something wrong with your motor or the switch .
Old Aug 4, 2012 | 08:17 AM
Silverfox08
Finally got it working. Got me a new switch.Works perfectly after the 10second programming . Thanks guys
Old Aug 4, 2012 | 09:13 AM
soolman32's Avatar
soolman32
Just out of curiosity. Did you check to make sure the window lock on the driver side wasn't engaged? that will prevent your window from rolling up. If that's not it then I'd say you are right and a new motor is needed.
Old Aug 8, 2012 | 12:03 PM
Silverfox08
Yeah it wasn't engaged..all I changed was the driver window switch and It worked..
Kojack
Oct 9, 2015 05:53 PM
RexHavoc
Oct 2, 2015 11:47 AM
parkern
Oct 1, 2015 10:15 PM
k19g37x
Sep 29, 2015 02:46 PM
