Help Linking seats to key
I looked all over the manual + searched the forums.
Does the g37 coupe NOT have the option of seats automatically moving back + going into position when you unlock the car with a certain i-key?
if you mean can the 2 IFob's be linked to the 2 different memory settings for the seat then yes, they can. It's page 3-30/3-31 of tha manual.
Here is a link to the manual so you can actually find what you're looking for in the future
http://www.infiniti-techinfo.com/ref...finiti-G37.pdf
http://www.infiniti-techinfo.com/ref...finiti-G37.pdfit says "this means it is ready to be linked with the i-key" but not how to.
Straigh from 3-31 --
Linking Intelligent Key to a stored
memory position
The Intelligent Key can be linked to a stored
memory position with the following procedure.
1. Follow the steps for storing a memory
position.
2. While the indicator light for the memory
switch being set is illuminated for 5 seconds,
push the unlock button on the Intelligent
Key. If the indicator light blinks, the
Intelligent Key is linked to that memory
setting.
Push the ignition switch to the OFF position,
and then push the unlock button on the Intelligent
Key. The driver’s seat, steering wheel and
outside mirrors will move to the memorized
position.
Confirming memory storage
● Push the ignition switch to the ON position
and push the SET switch. If the main memory
has not been stored, the indicator light will
come on for approximately 0.5 second.
When the memory has stored in position, the
indicator light will stay on for approximately
5 seconds.
● If the battery cable is disconnected, or if the
fuse opens, the memory will be canceled. In
this case, reset the desired position using
the previous procedure.
● If optional Intelligent Keys are added to your
vehicle, the memory storage procedure to
switch 1 or 2 and linking Intelligent Key
procedure to a stored memory position
should be performed again for each Intelligent
Key. For additional Intelligent Key information,
see “KEYS” earlier in this section.
memory position
position.
setting.
position.
5 seconds.
too much work if you ask me
what I've done is set the memory 1 to my driving position and 2 to the comfy so I can enter and leave easily .. once i get into the car I just press 1 and when im leaving i press 2
easily done
easily done
that's exactly what I do, but memory 1 is set to my key fob so that when I get in the car it is sliding into the right position. It is really not difficult at all (and if this is too much work then I would hate to see what is "normal work") lol
makes a huge difference b/c i always lean on the seat and left a stretch mark on the leather.
RexHavoc
Oct 2, 2015 11:47 AM
FlyIce
Sep 29, 2015 04:07 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
