Help Wiper Blade Replacement
Old Jan 2, 2011 | 04:28 AM
  #31
Hapa DC5's Avatar
Hapa DC5
Gonna apply some rain-x tomorrow for added visibility.
My stock wipers didn't even last our first rain. I didn't have time to go to the dealer (streaking really bad bought the car in July) and picked up a pair of Bosch Icons after work. Much better.
Old Jan 29, 2012 | 01:34 PM
  #32
joswald21's Avatar
joswald21
How to replace Wiper Refills - 2009 G37
Here is how it's done.
It's embarrassingly simple once you RTFD and use a pair of needle-nose pliers. See the attached PDF...
File Type: pdf
Old Nov 21, 2012 | 02:53 PM
  #33
mrg2001's Avatar
mrg2001
I have a 2009 G37 sedan. The passenger side wipers are supposed to be 17" but I bought replacement blades and are too long. The factory ones measure 16". Has anyone else noticed this?
Old Nov 21, 2012 | 03:50 PM
  #34
canucklehead's Avatar
canucklehead
for the sedan the driver side is 26", passenger side is 16". 17" passenger will rub the window moulding. coupe is 17", not sedan.
Old Nov 21, 2012 | 05:14 PM
  #35
ondatrack's Avatar
ondatrack
I like the look of the stock arms,when its time for new wipers ill get the refills.
Old Jul 19, 2015 | 10:07 PM
  #36
G37xsfun's Avatar
G37xsfun
I just ordered a few sets from orderinfinitiparts.com. $5.49 each for my 11 sedan.
Part numbers are:
288953NA0B sedan left
28895JK61C sedan right
Old Jan 29, 2018 | 10:52 AM
  #37
The OEM refills are simple to replace and cost $8 or less currently~
* 2009 models only
28895JK61A Sedan Right
28895CB08C Sedan Left
28895CB08C Coupe, Vert Left
28895JK01A Coupe, Vert Right
Click this link and enter your year to get the proper blades for your G, there's different part #s for almost every year!
https://www.orderinfinitiparts.com/p...wiper%20refill
Old Feb 3, 2018 | 04:11 PM
  #38
JSolo's Avatar
JSolo
Just say no!!!!!
Ordered some refills from https://discountinfinitiparts.com as they didn't rape on shipping.
For 2012 sedan
https://discountinfinitiparts.com/pa...blade%20refill
Ordered 288951AA0A (driver side), 28895JK61C (pass side). Part numbers came from their online catalog.
Received 28895JK65A (driver side) and 28895JK66A (pass side). Although numbers didn't match, driver side fit fine. Passenger side has the lock off by about 1/2" so it's sticking out and looks like this.
We'll see how this gets resolved. It is functional but looks tacky. The whole idea of going oem is to avoid this.
Edit: I looked very closely at the original insert.
It's stamped Mitsuba MOB2-S2-085 400mm . Could someone else with a sedan take a look to see what theirs say? Other posts on here reference a 425mm length (although that's for coupe I think).
Old Feb 4, 2018 | 08:35 PM
  #39
Strange that the numbers they sent didn't match unless they've possibly been recently superseded???
Also interesting that almost all years have different part #s, did they really change the arms each time or do they just complicate things by all those different part #s???
Old Feb 4, 2018 | 11:46 PM
  #40
JSolo's Avatar
JSolo
Just say no!!!!!
You know the really messed up part, what's stamped on the new refill is the same as what's on the old, yet the lock portion of it is in a different place, about 1/2" closer to the end.
I don't know why nissan complicates this so much. I can see a coupe possibly being different from the sedan because of different windshields, but aside from that, not sure what else could be different.
The seller did respond offering to refund for both, but that still doesn't solve this. Maybe next time I'll buy a full passenger blade from the dealer and bring both of these refills in for comparison.
Too much hassle to deal with shipping back and ordering another set. The refill spaced such that all the groove guides are used so good support. They work well without streaking or skipping.
Old Feb 24, 2018 | 09:27 PM
  #41
llebcire's Avatar
llebcire
Originally Posted by terrycs
For those that want it, refill replacement instructions here:
https://docs.google.com/fileview?id=...thkey=CJCA-pQD
Thanks for sharing this!
-Eric
Old Oct 5, 2018 | 08:03 PM
  #42
takemorepills's Avatar
takemorepills
Tried to replace my Q60 wiper inserts today, it appears that I don't have OEM blade assemblies anymore, and that the wrong sizes are installed on my coupe. I have OEM inserts, and they don't match either wiper assembly, and it seems the short assembly is on the drivers side. Can you guys tell me if this is messed up? I think I need to buy OEM wiper assemblies.....:
Old Oct 6, 2018 | 07:14 PM
  #43
codeflux's Avatar
codeflux
20 Year Member
i ordered a set of trico flex yesterday, 26" and 16" for my g37, on amazon for $24 shipped. in my experience, these work better than OEM and last longer.
q60 has different sizes IIRC, check it.
Old Oct 6, 2018 | 10:01 PM
  #44
takemorepills
I ordered OEM assemblies from Infiniti yesterday. After doing more research, the blades on my car are both wrong sizes and non-OEM. Q60 is same as G37 Coupe.
Old Oct 6, 2018 | 10:44 PM
  #45
ILM-NC G37S's Avatar
ILM-NC G37S
They appear to be reversed. The longer wiper is for the driver side while the shorter one is for the passenger side.
