Got my UOA from blackstone labs, Now what the **** do I do with it?
Old Sep 11, 2009 | 11:51 AM
wakeboardr116's Avatar
wakeboardr116
As the title says. I heard about people getting these, so i figured I try it out to see how the mobil 1 is doing. I'll attach the pdf for people to look at.
Pretty much what I got from it is that the engine was still finishing breaking in, there wasnt anything serious to worry about, and I can go about 6k before my next change.
Old Sep 11, 2009 | 11:59 AM
nogoodname's Avatar
nogoodname
whats with the wrong engine description and leaving ur address on there...lol
print screen and remove it
Old Sep 11, 2009 | 12:03 PM
ucla bruin's Avatar
ucla bruin
Haha yea, might want to take that off. I'm no expert at UOAs, maybe Mike can chime in.
Does it matter if his sodium and calcium levels are a little higher than the average?
__________________
Old Sep 11, 2009 | 02:53 PM
wakeboardr116
I dunno why they have it as a 3.6, but I'll take my address off. Thanks for pointing that out. Didn't even think about it.
Old Sep 16, 2009 | 04:04 PM
terrycs's Avatar
terrycs
post it over here for comments:
VQ Oil Analysis and Info - MY350Z.COM Forums
Old Sep 16, 2009 | 04:21 PM
goomba's Avatar
goomba
I'd be very weary of high levels of lead in UOA... that indicates higher than normal bearing wear. However, if this is only your third oil change, then that may explain it. With a new car, I don't see why you would exceed 3750 mi factory specified change interval at risk of voiding warranty claim should your motor blow for some reason.
Also, how are you collecting the sample? The right way is to collect the sample as its draining from them motor. Don't get a sample from the drain pan after since it will be contaminated.
Another option is to switch to another brand of oil and see if theres any improvement. I've only heard bad things about Mobil 1 5W/30. UOA's on other cars have shown that the 5W/30 sheers down to ~20 W over time.
Old Sep 16, 2009 | 05:37 PM
wakeboardr116
Infiniti doesn't require 3750 between changes. Its just recomended. I changed it at that interval for the first 2 changes, then i switched to synthetic and the guy at the service dept. said i could probably go 5000 between changes now. I'm not sure how they collected the sample, i just gave it to them and asked them to do it.
I'm planning to go away from mobil 1 soon. The only reason i got it again cause i was in desperate need of an oil change and that was the best availible at the moment. Everyone talks about motul oils and i track the car every now and then, so i will probably switch to that on my next one.
Old Sep 16, 2009 | 05:44 PM
ucla bruin's Avatar
ucla bruin
Try Eneos. My UOA is floating somewhere on the forum. Result was good.
__________________
Old Sep 16, 2009 | 06:59 PM
2009G37's Avatar
2009G37
Whoa whoa, you've ONLY heard bad things about Mobil 1? I've heard lots of good things about it??? So what are these bad things? Man, just when I thought I at least had the oil part kinda figured out.... Actually, I've even heard some people say that oil is oil, and that if you change it frequently enough, it really doesn't matter what brand you use.
Old Sep 18, 2009 | 07:00 PM
goomba's Avatar
goomba
Lets say for some reason your engine blows and you bring your car to the dealership in order to have it fixed under warranty. The first thing they will look at is your service records. All car manufacturers "recommend" a certain interval; in this case 3750 mi for the VQ. They then proceed to deny your warranty claim since you failed to follow their recommended oil change interval.
Old Sep 18, 2009 | 07:04 PM
Welcome
Good reading.
So when your engine blows and you tell the regional rep that you changed your oil every 5k and then he denies your warranty claim you are going to cite that guy at the service dept who told you so?
I guess he'll cite his Owner's Manual that says the car is designed to go up to 7500 miles between scheduled oil changes.
Old Sep 18, 2009 | 07:06 PM
goomba's Avatar
goomba
Welcome
Good reading.
If thats wat the manual says, then no problem. Thought it said 3750
delfinparis
Nov 16, 2015 02:26 PM
Vector x Prime
SouthEast
52
May 5, 2013 03:24 AM
