Illuminated Kick Plate Trouble
Hoping someone can help!
New G37. Had dealer install illuminated kick plates. Looked like there was moisture or water under the clear plastic (between clear plastic and black backing).
Waited 2 weeks -did not go away. Dealer replaced with new set.
Today I noticed a bit of the same again on both for the first time since they replaced them.
Anyhow had it happen to them? Help!
I have no idea how this happens but i have the same problem, on my passenger side is been like that since the beginning works perfect as of now i wont mess with till it goes bad but thats just me.
Shouldn't happen if installed correctly. They don't have any moisture below when installed via factory. Take it back and if they can't get it right, just have them put your standard ones on and get your money back.
So it is moisture or trapped air? --- BooSa37 let me know if you were able to get rid of it by rubbing it out with a cloth. I just make sure it is non-abrasive....if any light scratches happen, try the Meguiar product for buffing plastic headlight covers...
misc
29
May 24, 2023 03:57 PM
timc00k
Feb 15, 2017 09:15 AM
mjnoles1
Oct 4, 2015 10:27 PM
