G37 back lights
Old Feb 26, 2009 | 01:16 AM
4dynasty's Avatar
4dynasty
G37 back lights
Is there a manual or anything that shows you how to take the back lights off...i wanna get mines tinted
Old Feb 26, 2009 | 01:19 AM
aliiin's Avatar
aliiin
BMW Defector
are you doing overlays or spraying them? i think someone has a diy on this... search for it
Old Feb 26, 2009 | 01:21 AM
Wezbian's Avatar
Wezbian
Its simple, pull up on the plastic piece where the trunk latch is, undo the carpet clips around where the lights are, and unbolt 3 nuts on each light. Should be 8mm nuts.
Old Feb 28, 2009 | 12:54 AM
4dynasty's Avatar
4dynasty
I took the 3 screws off but i think its something else holding it up...2 lil ***** on the outter ends
Old Feb 28, 2009 | 01:13 AM
STOOF's Avatar
STOOF
after you take the 3 screws off, yes there is 2 pieces holding the light in.
You can either:
1. Grab the light and pull it straight back, mad hard.
2. From the inside, find the piece thats clipped in, put something against it like a small pipe or something, and hit the end of that lightly to pop the clip out.
Its not really that hard, its just clipped in there pretty good. I did the second one i wrote and it worked fine, much easier than pulling on that sucker for awhile.
Old Feb 28, 2009 | 01:44 AM
Wezbian's Avatar
Wezbian
mallet on the screw tops ftw
Old Feb 28, 2009 | 01:56 AM
Ivoidwarranties's Avatar
Ivoidwarranties
https://www.myg37.com/forums/faq-and...aillights.html
Old Feb 28, 2009 | 02:53 AM
NismoVQ37's Avatar
NismoVQ37
Getting rear-ended doesnt work that well fyi. At this point, id be happy with a stock working tail light.
Old Mar 1, 2009 | 04:39 AM
akuma_83's Avatar
akuma_83
check the DIY section... i think Ivoidwarranties posted the link... its a piece of cake... easy mod to do !
SS2006
Aug 27, 2024 07:33 PM
superjoey
31
Mar 22, 2023 11:56 PM
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
