DIY: How to remove the rear taillights.
Old Jan 25, 2009 | 04:32 PM
Ivoidwarranties's Avatar
Ivoidwarranties
I was looking through some old posts and had a hard time finding all the information I was looking for, so I thought I'd try to put some pictures together that might help others in the future.
1. This is from the shop manual which I didn't have at the time I did the taillight removal. But I have it now!!!
2. This is what you will start with hopefully, an empty truck with access to the interior trunk trim.
3. The trim is held in place by a few black plastic fasteners.
4. Once the trim is pulled out of the way you are looking at the metal body/frame. There are three nuts holding the taillight to the body and two alignment pins which also double as holding clips. Remove the nuts from the studs.
5. After the nuts are removed pull the whole light assembly straight back. The three studs the nuts were connected to run through rubber grommets and those grommets may give you a little resistance when pulling the studs out. The tricky part is the clips/alignment pins. They require a quick solid pull of the entire assembly straight back.
Here is a picture of the car after the assembly is removed. Notice the holes for the clips.
6. Here is the assembly removed. Next step would be to disconnect the wiring connectors which I did not do.
7. While you're here, do me a favor and pull that button out and paint it something other than chrome.
8. Here is the interior trim exploded view from the shop manual.
Old Jan 25, 2009 | 04:35 PM
Great write up. Just for info, what size are the 3 nuts you have to remove? Replacing back up lights with LED?
Old Jan 25, 2009 | 04:38 PM
ucla bruin's Avatar
ucla bruin
Thanks for the DIY!
__________________
Old Jan 25, 2009 | 04:42 PM
elite's Avatar
elite
Nice! Great write up!
Old Jan 25, 2009 | 04:43 PM
Ivoidwarranties
They are 8mm, 10mm, or 11mm. I knew someone was going to ask about that and I can't remember. I do know it's one of those though.
That was to get rid of the ugly chrome button.
Old Jan 25, 2009 | 04:44 PM
The1andOnly's Avatar
The1andOnly
By any chance do you have the DIY for the rear bumper removal?
Old Jan 25, 2009 | 04:48 PM
oOmikeyboy's Avatar
oOmikeyboy
Nice, this will definitely come in handy one day.
Old Jan 25, 2009 | 04:52 PM
Ivoidwarranties
Not yet... .
Old Jan 25, 2009 | 06:14 PM
VIP G's Avatar
VIP G
this is real simple so don't be afraid to try this guys. any noob can do it
Old Jan 26, 2009 | 12:33 AM
Where the hell are the photos of what you did instead of the chrome trunk button?
FWIW, I actually like it a lot.
Old Jan 26, 2009 | 02:10 AM
NIGHTLFEphantom's Avatar
NIGHTLFEphantom
What's the difference with LED replacements? pics?.. BTW nice write up IVW!
Old Jan 26, 2009 | 06:34 AM
Ivoidwarranties
Some people like the chrome button, personnally I couldn't sleep at night (she couldn't either).
https://www.myg37.com/forums/g37-cou...econd-mod.html
Old Jan 26, 2009 | 09:38 AM
CHI-TOWN G37's Avatar
CHI-TOWN G37
"Just when I didn't think you could be any more dumber, you go ahead and TOTALLY REDEEM yourself". Ha!
You are to be commended. That is a great writeup and for what it's worth I like your(her) lipstick red trunk button on that V-Red!
Old Jan 26, 2009 | 03:08 PM
OK, the button does look great in red but that's an awful lot of work for such a small part. Kudos to you for being the detail oriented **** sumbich you are!
Old Jan 26, 2009 | 08:52 PM
Ivoidwarranties
Thank you, thank you very much... It's really not a lot of work. The prep and paint for the button took most of the time.
