HELP! Stuck in limp mode with code p0355 and U0101
Old Oct 5, 2025 | 02:00 PM
Gbquavo17's Avatar
Gbquavo17
My car has been stuck in limp mode with crankshaft position sensor code P0335 and U0101…. I have replaced the sensor 2 different times once from AutoZone generic the car jerked really bad , 2nd one from a brand named Densa all it did was crank and no start ???? What could be wrong i need help figuring it out. The original sensor for the car doesn’t have any symptoms only limp mode and I can’t get it over 60 mph .. ????? What should I do
Old Oct 21, 2025 | 01:02 PM
Nesnetrom336's Avatar
Nesnetrom336
Hey got a question for you
Hey bro I have a question for you, is any of the gears catching normal, what I mean by this is when you put it into drive does it go into gear as well as all the other gears, or is it not catching and won’t even drive backup etc…?
Casey A. Coker
Mar 5, 2026 09:45 PM
Helpmewithmycar
Dec 27, 2023 10:05 PM
stcam
Jul 21, 2023 04:08 PM
chassman1
Sep 29, 2022 02:37 AM
SamL11B
Jul 6, 2019 07:21 PM
