Need Maintenance Help
Old Jun 23, 2024 | 09:35 AM
vengeance_g37's Avatar
vengeance_g37
I recently took my 37 to an auto parts store to see why my check engine light was reading. The code P0505 came back and I was told I needed to replace the throttle body’s, so I did. I bought aftermarket throttle body’s and replaced them, but the car still had the same issue; check engine light, constant limp mode, having a acceleration and deceleration in the idle, and what sounds like trouble to start. I’ve been to my dealer 3 times and they can’t help me, what can I do?
Old Jun 23, 2024 | 10:21 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Check all of your vacuum hoses for leaks. 99% of the time whenever there are idle surges the issue is a leaking vacuum hose or a fuel delivery issue (rare). The P0505 is merely a performance code that says the ECU is unable to meet and sustain a consistent target idle speed (650 +-50rpm (depending on load)).
You likely did not need to replace the throttle bodies.
Rule #1: NEVER throw parts at a problem without fully identifying the problem.
Old Jun 23, 2024 | 04:59 PM
SkysG37's Avatar
SkysG37
Did you go through the idle air relearn prosses?
are you aftermarket TS stock replacements? Or Oversized?
if Oversized, you'll need to tune the ECM to match
Old Jun 23, 2024 | 05:07 PM
ILM-NC G37S
Originally Posted by SkysG37
...are you aftermarket TS stock replacements? Or Oversized?
Good catch, SkysG37.
+1 for Idle Air Relearn procedure.
Camgarcia19
Oct 5, 2022 08:10 PM
Quiver
Jun 9, 2021 10:17 PM
venmichaels
12
Nov 27, 2017 04:40 PM
MrNiki
Feb 23, 2017 02:14 PM
