Check engine light on
Old Nov 9, 2023 | 06:05 PM
G37ru's Avatar
G37ru
I have a 2013 g37x with 70k miles. My right motor mount has been badly damaged for about a month (I know why would I wait a month don’t ask). But since it’s been damaged my car has been having heavy vibration when idle and when I push hard on the pedal it sounds like it’s hitting metal to metal. I took it to my mechanic and he was accelerating while braking and it triggered the check engine light to cut on. There was a delay in response when he would accelerate my car. I got the car at 53k miles and never cleaned the throttle body, never changed spark plugs, or really had anything done to it besides oil change and brakes. Also my car has been pushing forward a little when braking which causes me to brake a little more so my car can come to a complete stop may be brake fluid not sure but that hasn’t started since the check engine light has come on. A code also popped up P010C. I’ve ordered oem MAF sensors (2). Also ordered z1 motor mount kit. Can anyone tell me what may be wrong with my car. Or have experienced the same thing
Old Nov 15, 2023 | 10:57 PM
SkysG37's Avatar
SkysG37
This is a shot in the dark,
but knock sensors have been known to misinterpret rattles and thumps. This would cause the ecm to pull timming and/or "limp".
loose motor mounts are also known to take out wiring harness and anything else in the way.
double check ALL your mounts, bushings and dampers.
suspension components too
Camgarcia19
Oct 5, 2022 08:10 PM
G37Maniac2787
Jul 29, 2022 03:09 PM
Quiver
Jun 9, 2021 10:17 PM
soldier9599
Jun 16, 2020 02:04 PM
lakers8
Sep 9, 2008 10:01 AM
