Reverse Signal Question
I've been trying to diagnose an issue that's causing me not to have reverse lights, back up sensors, or back up camera, and hoping someone can tell me what the issue might be.
When I put the car in reverse, on the gauge cluster, the car moves from P to R, and goes into reverse fine. I ran the diagnostic menu on the Navi this morning, and when I put it in reverse, the section titled Reverse does NOT move from OFF to ON, which I assume is why the cam/lights/sensors aren't realizing the car is in reverse.
What would be causing this, where the dash is recognizing it, but the screen on the navi is not?
Easiest test, locate the M69 relay and identify the GROUND wire that comes FROM the TCM. With key ON (not ACC) and in PARK, use a small jumper wire and touch that relay socket terminal to bare metal and see if the relay clicks/ camera, lights turn ON.
Or, alternatively, you can test using this method.
I'm assuming you've read the other threads regarding this issue so that will spare me having to repeat.
rocky369875
Apr 21, 2019 09:53 PM
LVASJR
Sep 14, 2015 07:37 AM
