Instrument cluster lighting
Old Apr 12, 2022 | 09:46 AM
22BR's Avatar
22BR
2009 G37S / 6MT purchased used with 70k miles in 2019. When I bought it the coolant temperature gauge ‘face’ lighting would occasionally be inoperative. It seemed possibly linked to ambient temperature as it almost always worked when it was 60 degrees or warmer but was more intermittent at lower temps. In addition, the tachometer face lighting (7 - 9,000) would occasionally flicker as well. The pointers on both instruments (as well as everything else in the cluster) have always worked normally. Now at 98k the coolant gauge face is dark almost all the time with occasional drives when the face is illuminated.
Is there a particular harness/wire/connector I should be looking at? Or, is this an internal fault that requires a cluster removal and repair? Should I anticipate the pointer illumination may fail as well in the future?
Thanks for your help.
Old Apr 12, 2022 | 10:38 AM
iCrap's Avatar
iCrap
https://www.myg37.com/forums/audio-v...reen-swap.html
I posted some pics of the internals of the cluster here.
Unfortunately, your issue it a bit worse than my center screen failing because you can't just swap it out (without losing the mileage). The issue is the solder joints / LEDs failing on the cluster backlight. The only proper fix to retain mileage is to desolder and replace all the individual LEDs on your cluster backlight.
Old Apr 12, 2022 | 11:15 AM
22BR's Avatar
22BR
Thanks - I reviewed your DIY post; nice job. Not sure I want to tackle this yet but I may not have a choice someday. How difficult is it to remove the instrument cluster from the dash?
Old Apr 12, 2022 | 12:34 PM
iCrap's Avatar
iCrap
It's not too hard. I included a video of another guy taking it out in my post. I've taken it out like 3 times, probably only takes me 15-20 minutes at most.
Old Apr 12, 2022 | 01:41 PM
22BR's Avatar
22BR
Okay - doesn’t sound as bad as I thought but I expect the first time takes the longest. Would hope to only do it once!
Old Apr 12, 2022 | 01:55 PM
iCrap's Avatar
iCrap
Yeah, take note of my mistakes in the post. I ended up pushing the needles too far down the first time and they slipped, so I had to re open it.
Benson Tuo
Jul 4, 2025 11:32 AM
BrokenBoy
May 10, 2021 02:04 PM
hey.itsHel
Sep 17, 2018 12:44 PM
NeverBoneStock
Jul 11, 2012 02:59 PM
