Misfire cylinder #2 mechanic stumped
Old Sep 12, 2023 | 09:55 PM
GabeDJ2's Avatar
GabeDJ2
Originally Posted by tripps6x
I saw some videos on yt it sounds dope I’ll look into some hfc the ones I saw like berk are 550$ usd for some pipes I don’t know
What did your mech do to fix the misfire? Im having the same issue, misfire in cylinder 2, but I got new spark plug, new coil. Still throwing a code. Even tested new spark plug, old coil and old spark plug with new coil, same result. It doesnt feel like its misfiring at all though. I did have a very ****ed left cat and i got both of them replaced today, yet it still has the misfire code ):
Old Sep 13, 2023 | 11:30 AM
rotarymike's Avatar
rotarymike
Moderator in Moderation
easy way to tell if it's the injector is swap it with another cylinder, and see if the problem transfers. If not, then it's the wiring/ECU assuming you've done the same test with spark plug and coil (it could also be the wiring to the coil, but that's easy to check with a spark plug checker in line with the coil/plug).
Matta_Richard
Apr 9, 2026 04:58 AM
kimjackson
General Tech Questions
Feb 3, 2022 03:04 PM
Bryan Reyes
Feb 2, 2022 10:00 AM
Leon Engle
Feb 11, 2019 02:23 PM
Jhinds
Mar 28, 2018 02:44 PM
