toe adjustment maxed out, still not in spec
Old Feb 12, 2022 | 10:34 AM
Ponyryd's Avatar
Ponyryd
Originally Posted by projectpanda13
just so we are on the same understanding, when you say the spring perch, you are referring to what the springs sit inside correct?
if so, it also states in the description of those toe rods from z1 that it replaced that perch/bucket.
Ahh, I see that now…I just did a quick search on Z1 for toe arms and skimmed through it, didn’t see the notes in red that says they take the place of the buckets, lol. Good catch.
Old Feb 12, 2022 | 07:45 PM
Wide boi's Avatar
Wide boi
Installed the spc bolts and traction arms (which I probably didn’t have to do but **** it) and my toe looks good I adjusted the camber best I could. just drove it around for a little it’s not wandering like before, I’d say overall success. We’ll see in a couple days when I get an alignment probably gonna have to run a bit of negative camber.
Old Feb 13, 2022 | 09:21 AM
ryanwhite74115's Avatar
ryanwhite74115
Define negative camber? OEM camber specs to my knowledge are already something like -.5 or -1.0 degree in the rear. I run 2 in the rear and have noticed no tire wear issues from excess camber.
Old Feb 13, 2022 | 02:10 PM
Wide boi's Avatar
Wide boi
without the toe bolt had to have it at almost -5.5 if i could have it at 2-3 that would be fine
did a half assed alignment with the handle of my jack resting on both sides of the wheel and my phone as a level they were both at about -2°, didnt feel like doing the string method for the toe but i could see it was inward a little bit on the right
Wide boi
Feb 10, 2022 07:21 PM
ItsDeagle
Jan 5, 2022 10:00 PM
supreme
Jul 28, 2017 12:02 AM
JC-RH
Apr 10, 2014 05:15 AM
TVPostSound
Dec 6, 2012 01:41 AM
