Help Toe and Camber help/insight
Old Jul 2, 2017 | 05:24 PM
supreme's Avatar
supreme
Smile Toe and Camber help/insight
Hi All -
About to get some Tein Flex Z's (true coilover) for my coupe. I need some transparency on the camber and toe suggestions.
Only looking to eliminate fender gap in front and back. Need to know my options on correcting alignment specs.
Rear:
I know there are toe bolts (cheapest option), but not sure if I feel like dealing with the grinding of the existing bolt hole. Would you rather go the toe arm instead?
Camber, assuming is needed.
Front:
Are camber arms needed? Also, is OEM toe adjustment in the front good enough, or will that need to be replaced with another component too?
My old 05 TL, I just threw on the coils, and could adjust the toe. So I am knowledgable to coils, but ignorant to arms/bolts.
Any valuable resources are useful as well. Thanks in advance.
Old Jul 2, 2017 | 10:44 PM
With a true coilover rear mount you can eliminate the OEM lower control arm (aka spring bucket) and use camber arms and toe arms to get your alignment proper. Won't have to do any drilling and won't have the possibility a toe bolt getting loose when really pushed on a regular basis.
Front toe is fully adjustable through the tie rods, and if you keep the drop on the milder side your camber may be close enough to spec to still get reasonable tire wear, but YMMV.
Old Jul 2, 2017 | 11:10 PM
Crazyirish's Avatar
Crazyirish
Did they release a new version? I only see one listing for the Flex Z and I know its not a true-type coilover in the rear.
Old Jul 3, 2017 | 01:43 AM
slartibartfast's Avatar
slartibartfast
Stock front suspension only provides toe adjustment. You have to buy adjustable upper control arms if camber or caster need adjustment.
Old Jul 5, 2017 | 12:32 PM
supreme's Avatar
supreme
Thanks for the insight guys.
How often does the toe bolt slip? I would just be doing DD,
no track. Is it that much of an issue?
In addition, what would be considered a "mild drop"
to not need camber adjustment in the front? I just plan on eliminating the disgusting wheel gap, and maybe a slight tuck.
Old Jul 5, 2017 | 02:17 PM
It varies, every drop seems different as far as alignment readings. A 1.25" drop should be ok for no camber help up front, but never say never.
I've had my SPC F&R full kit and never had any problem w/ toe bolt changes, and that's over 6+ years & 75k miles ago
Old Jul 5, 2017 | 02:30 PM
supreme's Avatar
supreme
Excellent! Thanks for the insight. May opt out of the front camber for now, and go about it later if needed.
What drop do you have, and camber specs in the front?
Old Jul 5, 2017 | 04:10 PM
I'm dropped pretty low, to zero gap (about 26.25" to the fender arches on Sedan, on Megan Street LP coils, I'm about due for new ones though, probably just go Tein Street Basis next time around. My camber is right about -1.0 F and -1.0 to0 -1.1 rear, so I get extremely even wear across the tread block
Here's my G setup
Old Jul 25, 2017 | 12:07 AM
supreme's Avatar
supreme
Hey all - following up with the initial question. Turns out, I am dumb and thought the Flex Z came in the true coilover type. I was sadly mistaken (looking at stock photos). So I went OEM style, and will have no choice but to use a toe bolt.
Good news is, I got the SPC camber arms and toe bolts for $150 brand new locally.
Will be tackling this in the upcoming weeks.
Old Jul 27, 2017 | 08:48 AM
Check this thread if you haven't seen it~
https://www.myg37.com/forums/brakes-...-template.html
Old Jul 27, 2017 | 09:55 AM
xmajd92's Avatar
xmajd92
Got a question about rear suspension. So just to clarify, if I were to go Z1 Lower control arm and SPL toe link, is that all I need? Or will I also need the SPL eccentric lockout kit?
Old Jul 27, 2017 | 10:27 PM
You don't need the lockout kit, just another step to insure exact toe settings that won't have a chance to shift.
Old Jul 27, 2017 | 11:29 PM
xmajd92's Avatar
xmajd92
So if I were to track my car then the lockout kit would be necessary?
Old Jul 27, 2017 | 11:59 PM
Not necessary, but that would be the ideal application to justify their purchase.
Old Jul 28, 2017 | 12:02 AM
xmajd92's Avatar
xmajd92
I see. Thank you!
