My memory seat lights for auto setting 1 and 2 wont flash on driver door
Old Feb 3, 2022 | 05:23 PM
Infiniti7's Avatar
Infiniti7
Does anyone know how to get the memory seat lights to come back on for the settings one and two on a 2009 G37?
Thanks
Old Feb 3, 2022 | 07:39 PM
Infiniti7's Avatar
Infiniti7
Had to replace the door Actuator assembly because the cable broke and I wasn't able to open the driver side door from the outside. Now the seat memory lights wont light up or blink. What's the best way to fix this? Could it have to do with one of electrical panels in the car?
Old Feb 7, 2022 | 03:50 PM
Infiniti7's Avatar
Infiniti7
Does anyone maybe know a little something about this or have had an issue similar to this before? I appreciate it
Old Feb 7, 2022 | 04:38 PM
13_SkylineSedan's Avatar
13_SkylineSedan
Hmmm. Are you sure you got all the plugs reconnected as you put the door panel back on? Your owner's manual has several pages describing this seat memory function but here's the most important bit:
The seat synchronization function can be activated or canceled by pushing and holding the SET switch for more than 10 seconds while the ignition switch is in the ACC position.
The indicator lights on the memory switches (1 and 2) will blink once when the function is canceled, and the indicator lights will blink twice when the function is activated. Note that the indicator lights may illuminate after 5 seconds while holding the SET switch. This indicates readiness for linking the Intelligent Key to a stored memory position. Keep the SET switch pushed for more than 10 seconds to turn on or off the seat synchronization function.
It then goes on to describe how to capture the memory positions and how to sync them to different iKey fobs. Hopefully you can wake it up, I find this a handy feature.
Old Feb 7, 2022 | 05:22 PM
Birdie's Avatar
Birdie
Yep,
more than likely you forgot to plug it back in
Seat adjust man
Oct 14, 2020 11:35 AM
G37USA
Mar 3, 2019 05:17 PM
2010g-ride
Oct 14, 2013 12:15 PM
08G37Nuts
Apr 15, 2009 07:30 PM
Loi
Jan 28, 2008 01:23 AM
