Was wondering if it's possible to run wider rear tires on the stock G37S sedan rims? Nothing crazy, but I would like to have a little less sidewall. Would a 255/40/18 in the back be compatible with the 225/50/18 in the front? Or any other size permutation?
If I did this, would it impact handling in any discernable positive or negative way?
Thanks for your response. I had run a tire size calculator and saw the difference is -2.6% in diameter and wasn't sure what the acceptable cutoff was... what are acceptable differences when sizing tires? And is there any other size that would work on the stock rims?
Yeah I'd agree with above. While I do indeed run 245/45 in the front and 275/40 in the rear (truly the perfect combo btw), I have aftermarket wheels that are 9" in the front and 10.5" in the rear. Significantly larger than OEM. Please don't do a 275 on the oem rear rims, I'm not sure a tech could even work that.
The 04-06 GTO community was stuck with a 235 wide tire on a 8" wheels in stock form. Many people ran 275s however they did bulge quite a bit. This will be fine for straight line performance but it will for sure degrade your handling capabilities.
