Another coolant leak: Annoying heater hose on drivers side
Well noticed smoke coming from under the hood, to find heater hose from drivers side under the throttle body leaking. It was leaking from the middle of the hose a very narrow stream upwards. This was a pain to remove since there isnt much room there. I removed the intake, and few pieces that were in the way. Took me about 3.5 hours just to remove the heater hose. It is very hard to get pliers or a vice grip to grab the clamp. The clamp closest to the firewall was most difficult since the clamp was facing the bottom. I ordered the part from nissan and it should be here by saturday. Part # is 14055-jk20a. Will update once part arrives.
I have pretty much the same mileage as you. Anyways what I meant to say was, in order to remove that small broken hose, will removing the heater hose on top of it give me more room to work with?
