Sedan weight reduction
Old May 24, 2018 | 06:09 PM
  #106
4DRZ's Avatar
4DRZ
Nice rotors. I know those bad boys aren't cheap.
They are actually not too bad for 2pc. rotors. It was an easier pill to swallow than the rears since they are cheaper and save more weight.
Originally Posted by zer099
I do not doubt your scale or the info. Just seems everyone else is convinced the OEM rotors are 30 pounds. I'm guessing they went off of someones posted information then just feed off of each other but no one actually checked the facts. Do a quick google search. EVERYONE claims 30 pounds, even Centric. Typically how bad information gets spread. At least know we have the truth!
It's remotely possible the scale was not 100% accurate, but it is also the same scale that measured the Z1 rotors at exactly 20 lbs so the bigger issue is that both rotors were measured on the same scale on the same day so the difference in weight is accurate. I could see my stock rotors losing 1/8 lb. or maybe even 1/4 lb. in rust flakes and rotor use, but almost 2 full pounds? No way. Maybe a different (non-oem) brand of rotor uses more metal in the center or the vanes?
Old May 26, 2018 | 12:50 PM
  #107
ezbme's Avatar
ezbme
Knowing what I know there, instead of the rear bushing service, I would have bought these rotors on Black Friday, they were down at least $30. My rotors were 129 shipped, so I would still have paid 300 more, but it would be nice to save almost 20 lbs.
Old Jun 3, 2018 | 10:32 AM
  #108
4DRZ's Avatar
4DRZ
So I am starting to think my next step to lighten the car is to either get an expensive lithium ion battery with enough cold cranking amps for WI or get another Sparco R600 seat and rails for the passenger side.
The battery would probably be about $500 and I should probably do it this fall or next fall as the car turns 5 soon. The seat will be about $1,000 by the time I get the rails and the bypass for the weight sensor. (I would split this up over a few months so as not to break the bank.) I really just want the seat to match my driver's seat before they stop making them, but I will probably eventually do it.
Has anyone tried a lithium ion battery or other lightweight with as many or more cranking amps than the stock battery? In WI we can see windchills as low as -50 in the winter so I cannot skimp on CCA. The factory battery has been a champ so far. I am curious how much weight I would lose.
Old Jun 3, 2018 | 11:34 AM
  #109
Epiphany's Avatar
Epiphany
How much weight would you save off a battery? As someone also living somewhere with winter that's not something I'd worry about saving the weight if it has any chance of making it so my car won't start in the middle of winter. Especially if it's spending $500 to save 5 pounds.
Old Jun 3, 2018 | 05:06 PM
  #110
4DRZ's Avatar
4DRZ
I think it saves 25-30-ish lbs. I just have yet to weight the factory battery. Has anyone else?
Old Jun 3, 2018 | 10:50 PM
  #111
Epiphany's Avatar
Epiphany
I replaced my battery with the size of battery of an M37 ( group 24F), it weighed 41lb. Our car takes a group 35 battery which would've been 36lb for the brand I got. Guess we went the opposite way on this front.
Old Jun 5, 2018 | 06:20 PM
  #112
4DRZ's Avatar
4DRZ
Does anyone know the weight of the factory battery? I talked to Gary at Braille and the G30 sounds like a good option for me and should save a lot of weight, but it is a bit pricey. Anyone have experience with Lithium Ion batteries?
Old Jun 6, 2018 | 01:26 AM
  #113
slartibartfast's Avatar
slartibartfast
I hate to say this, but search. There was a discussion late last year about metal hydride batteries.
Old Jun 6, 2018 | 02:12 AM
  #114
antirice's Avatar
antirice
Stock battery weights about 41 lbs. Optima red top weights about 33 lbs.
Old Jun 6, 2018 | 11:49 AM
  #115
Mattlorentzoe's Avatar
Mattlorentzoe
Great thread learned a lot. Especially with the front seats. I was going to go similar route, now I’m just swapping for the ventilating/heated m seats. Already have a issue with hitting my head on sunroof with helmet on lol. Interested to see where this battery discussion goes. I have a red top I swear by but it’s 3.5 years old so I wonder how long it will last. Love being able to leave car for 2+ weeks and it still cranks right up. If you can get a positive review on that battery I’m in.
Old Jun 6, 2018 | 04:13 PM
  #116
slartibartfast
As an aside, youtube channel Engineering Explained visited the Ultima factory and explained how they are made and the color coding.
Old Jun 7, 2018 | 03:42 PM
  #117
4DRZ's Avatar
4DRZ
I was talking to guys at Braille Battery and Optima about options other than Lithium Ion, but I need a lot of CCA for the winters up here in WI so those batteries get heavy by the time I get enough CCA. Leaning more toward Lithium Ion at this point.
41lbs!?! Wow, the Braille lithium ion G30 battery only weighs 5.5 lbs. This is going to save a ton of weight. Awesome!
Another battery I had recommended to me by a very good race driver was Antigravity. I spent a lot of time on the phone with the tech guys at Antigravity and they also recommended talking to Bart at Pegasus racing here in WI. He said their ATX-30 would be a good fit for me, but may require turning on the headlights in the extreme cold for 10-15 seconds to warm up the battery. Small price to pay for saving $300 over the Braille battery with similar performance.
Bart at Pegasus also mentioned that Antigravity is working on another battery that may be out next year that is unaffected by the cold and should cost a similar amount. Maybe I can stretch this OEM battery out a little longer until the new Antigravity battery debuts, hopefully sooner than later.
Old Jun 7, 2018 | 03:44 PM
  #118
slartibartfast
Dang! Though spendy, that's a great weight savings. I can use lower CCA here on the Gulf Coast.
Old Jun 7, 2018 | 03:56 PM
  #119
4DRZ's Avatar
4DRZ
Lucky devil! The Braille is $599, but the Antigravity is only $399. Both are a lot less than my seat and rails and save more weight so I can make sense of it.
Old Jun 8, 2018 | 12:29 AM
  #120
gord27's Avatar
gord27
Haven't read this whole thread but have you considered just changing the battery for the summer months? Then just change your battery when you change your tires.
