Rough Idle when in Drive. Please help!
Old May 10, 2016 | 08:52 PM
SS2006's Avatar
SS2006
Hi everyone. This has been bugging me for a few years now. Whenever I shift the car into D, the rpm dips (when I'm a stop light for example, so the car is idle), to the point where the car feels rough, and things vibrate a bit. I've learned to just put up with it, but I'm trying to figure out the problem. Car drives fine besides that, engine has never stalled, no engine codes.
Things I've ALREADY done:
-Cleaned MAF
-Cleaned throttle body
-No ECU error codes, or air leaks, that are at least obvious to detect
-Reset ECU
-Attempted an Idle Air Volume Re Learn (no idea if it worked), I even tried using the NDSIII app, but I kept getting 'ECU Busy..please wait'
Does anyone know what the spec (normal) RPM is for a G37x (2010 model)
I used an odb reader and I found that the RPM at idle (when in D) is 550. Is that technically normal, and in spec?
When in P or N, it goes up to 700 something, and the sound and vibration isn't as bad. Most of the sound/vibration is coming from right under me, and I'm pretty sure its the cats, hoping its the heat shield.
So what else should I absolutely trouble shoot next, as in it may be a high probability cause? I haven't asked the dealership about it yet, but my last visit to the dealership they said I need to change my rear differential oil (its past due), would that cause a rough idle in Drive?
EDIT: Found this video on youtube, is EXACTLY what my car sounds like. Hopefully that helps...
Old May 10, 2016 | 09:06 PM
VenomGT9's Avatar
VenomGT9
Cam position sensor perhaps?
Old May 10, 2016 | 09:12 PM
SS2006's Avatar
SS2006
Hm, possible. Wouldn't that throw an engine code though?
Old May 11, 2016 | 01:10 AM
SS2006's Avatar
SS2006
I read in the service manual idle speed (in P or N) should be 650 +/- 50.
Cant find anything about what it should be when in Drive. Can someone kindly get a reading from their car and let me know. It may very well be that 550 is normal, and there is just excessive rattling/vibrating from the heat shield or something, I'm not sure. Although it does sound like some diesel engine to me, and judging from the above video, I'm starting to think it is the fuel damper.
Old May 11, 2016 | 05:24 PM
jomama22's Avatar
jomama22
On my way to class so here you go my idles is pefectly smooth.
Old May 12, 2016 | 12:40 AM
SS2006's Avatar
SS2006
Thanks, OK that is like mine. So the idle RPM is normal, its just that mine isn't smooth at all. I'm almost 100% sure its the fuel damper then. I hope it doesn't cost much
Old Jan 1, 2017 | 02:57 AM
xxg00w0's Avatar
xxg00w0
Rough idle
so did you find a way to fix it or cause of the rough idle? My car has the same issue was it the fuel damper? If it is and you fixed it where and how much did they charge you?
Old Jan 1, 2017 | 01:00 PM
tite_tite's Avatar
tite_tite
Try changing plugs & oil. Has it always made the sound or new? Which oil use to change & has car been in accident before?
Old Jan 2, 2017 | 02:20 AM
crookncastle's Avatar
crookncastle
perhaps one of your motor mounts or related drivetrain dampener is worn or collapsed, hence the vibration at idle.
Old Jan 5, 2017 | 12:13 AM
jcho01's Avatar
jcho01
I had the same issue and got my throttle bodies, MAF, and Fuel Injectors cleaned out. The sound is gone and the acceleration is much smoother.
Chris Daher
Feb 26, 2017 05:34 PM
mjnoles1
Dec 7, 2016 02:27 PM
Willyr33
ECU Tuning / Dyno Data
Aug 24, 2016 03:46 PM
Nathan Benoit
Apr 5, 2016 12:54 PM
xstarpro
Apr 1, 2016 01:05 PM
