ECU Tuning / Dyno Data This subforum is specifically aimed at ECU Tuning reviews, questions, dyno charts, etc..
MAF Sensors
Old Apr 2, 2016 | 11:53 PM
Willyr33's Avatar
Willyr33
MAF Sensors
I'm wondering if it is totally necessary to upgrade your MAF sensors when going turbo charged to the G, is their any head room in the std sensors for some tuning?
What has everyone else done here in that regard going forced?
Appreciate any feed back, thanks
Old Apr 3, 2016 | 04:36 AM
PongSanity's Avatar
PongSanity
If you getting tuned via Uprev and have plans on running more than 15lbs of boost iirc then you'll need to upgrade the mafs. If you are getting tuned via ECUTEK then you don't need to upgrade the mafs. Ecutek allows for speed density tuning which is done off of the map sensor.
Old Apr 3, 2016 | 10:19 AM
Waste86's Avatar
Waste86
Pong is correct. Turbocharged keeps the dual inlets. Some supercharged people had to switch to different MAFs because they use one charge pipe, which can sometimes exceed the stock MAF voltage.
Old Apr 4, 2016 | 04:50 AM
Willyr33's Avatar
Willyr33
I most likely will be going with Uprev, wont be going over 13lbs boost
, will the standard maf senors handle that?
Old Apr 4, 2016 | 07:39 AM
PongSanity's Avatar
PongSanity
It's like a hit or miss at that level. You're better off upgrading the mafs to be sure.
Old Apr 4, 2016 | 12:00 PM
ANMVQ's Avatar
ANMVQ
13 LBS you'll need them. Both I and Cliff( 370Z) ran out out voltage at about 12 PSI. Stillen SC BTW
Old Aug 17, 2016 | 12:39 PM
Kris9884's Avatar
Kris9884
When we say upgrade, is this to some other OEM model or one of the aftermarket models? I don't plan on more than 10-12psi on Uprev and am keeping both pipes/MAF's.
Old Aug 17, 2016 | 01:03 PM
Kris9884's Avatar
Kris9884
Update: For anyone in the future searching this, our OEM MAFS are good with boost for up to and over 600WHP. Its all over the 370z boards..
Old Aug 24, 2016 | 03:46 PM
PongSanity's Avatar
PongSanity
600hp on how much lbs of boost tho?
Chris Daher
Feb 26, 2017 05:34 PM
Roan de Rossi
G37 Convertible
Apr 26, 2016 12:54 PM
Butternut
Apr 13, 2016 12:43 PM
Awgd8
Apr 2, 2016 11:13 PM
