Old Jun 1, 2018 | 10:33 AM
  #5311
Lego_Maniac's Avatar
Lego_Maniac
Originally Posted by G37fan09
Last week, did Diffuser and Ark exhaust. Enjoying the sound
That looks great
Old Jun 1, 2018 | 10:41 AM
  #5312
Body-colored spats on the diffuser... that's kind of neat. The resonated tips (which could really stand to be polished) look great in that gloss black surround. Very nice.
However, the diffuser significantly compromises the fitment of your license plate, and turns the mod into a hack job. Anything that can be done to fix that?
Old Jun 1, 2018 | 12:07 PM
  #5313
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Car looks great g37fan
Old Jun 1, 2018 | 01:19 PM
  #5314
Nico-derm's Avatar
Nico-derm
Build out the top with rubber spacer with built in screw or hollow Center and use a longer screw... would square it up
Edit: not sure tho after looking back to the close up if it’d look right either
Old Jun 1, 2018 | 01:46 PM
  #5315
It might not look right, but it might look better. And better is better than nothing. Very clever, Nico-derm.
Now I'm looking at this pic close-up, too. Look again at the fitment along to top, at the transition between the diffuser and the spats. The diffuser is actually mounted a half inch or more too high, which would explain the problem with the license plate. The diffuser it's intended to fit under the crease, not over it.
Ah, and you know why it's a half-inch too high? Because the exhaust tips were compromising the fitment. The entire exhaust needs to lower a half inch, or just the tips themselves somehow.
Or the diffuser needs some significant body work, either to increase the cut-out for the exhaust tips, or to dramatically alter the entire top of the unit. Either way, it's not right. I'm thinking the diffuser design specs are compromised because of the exhaust components.
Freaking huge ARK tips are butchering this mod.
Old Jun 1, 2018 | 02:58 PM
  #5316
Nico-derm's Avatar
Nico-derm
I agree from that angle it is probably designed to flush fit and not overlap... wonder if the tips were the only reason for the orientation. The body coloured spats lip as well when you look at the other pic
How would you get it to not overlap and not create a gap elsewhere is the question...
Edit: OP don’t take this convo the wrong way, it’s just what we do lol
Old Jun 1, 2018 | 03:37 PM
  #5317
G37fan09's Avatar
G37fan09
Body-colored spats on the diffuser... that's kind of neat. The resonated tips (which could really stand to me be polished) look great in that gloss black surround. Very nice.
Thanks I definitely will go w custom plate trying to fix that, don’t know how long it will takes. 🤷🏽*♂️
Old Jun 1, 2018 | 04:18 PM
  #5318
c1utchh's Avatar
c1utchh
I don't have a XM subscription.
Toggled to the XM source, nothing. A message that the radio wasn't activated and a commercial in the background.
I'm getting flash flood warnings and it's not even raining
you too huh? I installed the stillen grounding kit, and all of sudden every hour or when i start the car, I'm getting flood warnings. Started to drive me insane.
Old Jun 1, 2018 | 04:35 PM
  #5319
Plate isn't your problem. The diffuser needs to be under the bumper crease, not over it.
Old Jun 1, 2018 | 05:17 PM
  #5320
G37fan09's Avatar
G37fan09
Nope,
The inside of the diffuser has the shape of the bumper, it doesn’t fit under the crease. Two examples both over the crease.
Old Jun 1, 2018 | 05:34 PM
  #5321
G37fan09's Avatar
G37fan09
We try to fit it any possible way, but there is only one way because the inside of the diffuser has the shape of the crease. We manage to drill and put a screw inside the Diffuser.
The inside of the diffuser tells you how to fit.
Old Jun 1, 2018 | 08:13 PM
  #5322
Nope, The inside of the diffuser has the shape of the bumper, it doesn’t fit under the crease.
Hey, I believe you. I made some inaccurate assumptions. Thanks for clarifying things on the design.
So... how come the license plate doesn't fit? In both of those pictures, those other cars had their tag jammed up the exact same way. I think maybe Nico-derm's idea for spacers is worth looking into after all.
Old Jun 1, 2018 | 08:51 PM
  #5323
Lego_Maniac
Settings>Navigation>Weather Info Settings
...and turn all 3 off
Old Jun 1, 2018 | 09:21 PM
  #5324
G37fan09's Avatar
G37fan09
I like to provide info for the benefit of people interested in buying the diffuser.
Not everybody like it, and I definitely recommend to be install by a body shop. I installed mine w the help of a friend ( professional ).
Regarding the plate;
It’s the design, I would definitely like to try Nico spacers recommendation w a new custom plate
Old Jun 2, 2018 | 10:14 AM
  #5325
guy from norcal's Avatar
guy from norcal
G37fan. I think it looks good.
Don't mind Rochester, He has a little OCD.
