Old Feb 1, 2017 | 03:40 PM
  #2056
JustROLLIN's Avatar
JustROLLIN
After only owning it for a couple of weeks, just doing some of the basics:
- Replace engine AFs and cabin filter
- LED interior bulbs w/ lic. plates, trunk, etc.
- Replace wiper blades
- Install BT receiver, since mine is a non-nav 2013
Nothing crazy, just a few things to ensure everything is as it should be. Will probably clean up the TBs as well, even though it only has about 23k on it. That way I know they are clean and done.
Also, I am having a lot of condensation on the rear window. I will need to take it in to the dealer and have them check that out.
Old Feb 1, 2017 | 05:48 PM
  #2057
zonnie's Avatar
zonnie
R2C Intake, Tanabes Axleback, Vibrant Resonators
Old Feb 1, 2017 | 05:51 PM
  #2058
Furlow's Avatar
Furlow
With stock piping? Post a video so we can hear it! I have the same set up except with 2.25" piping. And Stillen G2 instead of R2C.
Old Feb 1, 2017 | 06:45 PM
  #2059
the93owner's Avatar
the93owner
About to get vibrant resonators paired up with my Tanabe also! They're sitting in my garage
Old Feb 1, 2017 | 07:47 PM
  #2060
Melophile's Avatar
Melophile
Got the Takeda long tube intake and Cusco strut brace in
Old Feb 1, 2017 | 08:11 PM
  #2061
mdigiorgio35's Avatar
mdigiorgio35
Originally Posted by Bear Slate
I got the steering wheel wrapped with a hand stitched leather cover!! The local shop that did it for me was amazing
how much that run you BearSlate?
Old Feb 1, 2017 | 08:14 PM
  #2062
tank99's Avatar
tank99
Simple - Performed the seat lowering mod and got some extra headroom. Not a huge difference but if your 6ft+ you should do it. worst case you don't like it or need it and just raise it back up.
Old Feb 1, 2017 | 09:07 PM
  #2063
Wangstas863's Avatar
Wangstas863
Autokitx diffuser in carbon fiber , save $45 by picking it up lol
Also got my fast intentions non-resonated hfc installed paired with ark exhaust. Some added drone (tolerable) , no rasp, I'm liking the volume .
Old Feb 1, 2017 | 09:08 PM
  #2064
ZahyMatar's Avatar
ZahyMatar
We need exhaust clips!
Old Feb 1, 2017 | 09:19 PM
  #2065
Furlow's Avatar
Furlow
Seriously. Should be a rule or something lol.
Old Feb 1, 2017 | 09:24 PM
  #2066
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Where in fl are you located?
Old Feb 1, 2017 | 11:17 PM
  #2067
Bear Slate's Avatar
Bear Slate
It was $250 but it was worth it IMO. He spent 6 and a half hours working on it.
Old Feb 2, 2017 | 07:17 AM
  #2068
VIVID's Avatar
VIVID
Pyroclastic Flow
Do tell!!
More info on this mod please. I have my seat as low as it will go, and depending on whether I shower or not, my hair scrapes the ceiling (6' 2" and change).
I do find I would like my thighs supported a bit more...I don't have S seats. Is being even lower uncomfortable? I would like to angle the seat bottom more (higher in front) to get my knees and thighs up.
Thanks, Sean
Old Feb 2, 2017 | 09:09 AM
  #2069
JustROLLIN's Avatar
JustROLLIN
Originally Posted by VIVID
Do tell!!
Thanks, Sean
Here ya go: https://www.myg37.com/forums/body-in...ml#post2249587
Definitely on my list.
Old Feb 2, 2017 | 11:16 AM
  #2070
tank99's Avatar
tank99
Thanks JustROLLIN. In the DIY referenced they had 3 washers, the raised, flat, then the rubber bushing/washer. I did not have the middle flat washer. All I did was removed the raised washer, replaced with a thin flat and the bushing, then put the nut just flush with the rod end. It's a lock nut so I don't think it will work itself off. It is a more comfortable drive and makes you feel less on top of the car. Took all of 15 minutes. They claim the Passenger is the same setup but I didn't check, and I'm not sure I care haha.
