OBD port locked
Old Dec 21, 2015 | 09:32 AM
3zouz3's Avatar
3zouz3
Thumbs down OBD port locked
guys,
i wanetd to read codes\PID via OBD2 port.
i have got BT dongle (ELM327) and Torque app on andorid.
i was able to pair the phone with the BT dongle.
i couldnt get any real time values\PID
the app says ( the vehicle ECU has not been enabled by your dealer for OBD2 access)
anyone knows anything about this matter?
anyone know how to unlock OBD2 port?
g37 sedan 2008
Old Dec 21, 2015 | 10:37 AM
Mr.Grant's Avatar
Mr.Grant
What country do you live in? You G might either not OBD 2 compliant meaning still using an OB 1 connection or the ECU wasn't enabled to be so probably because of the country it is in or originally in if you transported it from somewhere. Or you can try these steps below:
-Go into your "Vehicle Profile"
-Scroll down to "Use alternate Obd header" and check the box.
-Save your changes and then close and reopen torque.
Old Dec 21, 2015 | 10:46 AM
3zouz3's Avatar
3zouz3
Obd
Hi grant and thanks for replying
I live in dubai and the vehicle follows gulf specifications.
I dnt think it uses obd1 co i found many videos to the similar G getting connected via obd2.
I tried the option u mentioned but no hope
I am pretty sure the dealer locked the port so they are the only ones who can control the ecu.
So any idea how to unlock it ?
Old Dec 21, 2015 | 10:53 AM
Mr.Grant's Avatar
Mr.Grant
Hmm I've never had in experience doing so, but if it was me I would just go to the dealer or tuner to see if they can do and if the cost is to rich for you. A simple google search will probably show you how to unlock the ECU OR the port. Or maybe someone else will chime in here.
Old Dec 21, 2015 | 10:57 AM
3zouz3's Avatar
3zouz3
Believe it or not ..i spent like 6 hours googling today..i either dnt know how to google which i doubt .
OR there is no solution and no one unlocked it before 😂
But thanks for replying and waiting for the champ to solve this issue
Old Dec 21, 2015 | 11:14 AM
Mr.Grant's Avatar
Mr.Grant
this may give you a little more insight of the issue. But it seems like from what I researched you have to go to a dealer or a tuner. But I'm in to wait and see as well what someone on the forum says also lol.
Old Dec 21, 2015 | 09:52 PM
iCrap's Avatar
iCrap
That's really strange. i used the same app on my phone and it worked fine. I was able to read and clear codes even.
Old Dec 22, 2015 | 02:00 AM
crookncastle's Avatar
crookncastle
the obd2 data link connector port is a universal diagnostic plug outlet required of all manufacturers if they sale vehicles here in the united states. now the issue the op may be having is a software issue which the manufacturer may or may not allow certain vehicles to have access to when they are sold to different countries around the world. torq app on the android market is a generic obd2 software app, the op may need oem factory specific scantool with the correct software for his region in order to access the data supplied by the pcm.
Old Jun 9, 2019 | 03:24 AM
KWIMAZ's Avatar
KWIMAZ
I have the same issue
Originally Posted by 3zouz3
guys,
g37 sedan 2008
Did you solve the problem? I am from Dubai as well and having the same issue with my G37 2014 GCC Spec
Old Jun 9, 2019 | 06:57 PM
slartibartfast's Avatar
slartibartfast
Doubtful the OP still checks this board, he hasn't posted in three-and-a-half years.
Autmnkestrel
Jul 24, 2019 12:04 AM
LameG37
G37 Convertible
Jun 12, 2019 09:40 AM
AScobi64
Jun 6, 2019 06:00 AM
Paul N
G37 Convertible
Jun 4, 2019 04:55 PM
