Error code P0456 - Very small leak
Old Nov 16, 2015 | 04:34 PM
josefah's Avatar
josefah
I am getting the error code P0456 in my 2011 Journey Sedan. I already got the car smoke tested and they informed me that it was the EVAP canister had lost suction. I want to insure that this is actually the problem and not just a hose connecting to the canister. My problem? I am not sure where it is on the car. I saw some diagrams of G35s saying that it was in the rear by the muffler but i want to be sure before jacking the car up.
Thanks for any help.
Josef
Old Nov 16, 2015 | 05:07 PM
Welcome Josef!
Here's your answer:
Let me google that for you
Take a look at the images, the very first one. Good luck.
Old Nov 16, 2015 | 07:02 PM
josefah's Avatar
josefah
Yes I found underneath the rear skid plate. Thanks. It looks like one of the hoses is missing a hose clamp. I am going to start with that. All the hoses look to be in pretty good shape with no cracks or cuts.
I've already replaced the gas cap which could also throw that code.
Old Nov 16, 2015 | 07:19 PM
That missing clamp looks like your culprit.
Old Nov 16, 2015 | 07:32 PM
josefah's Avatar
josefah
I hope you're right. $3 vs $1100. Thanks for the help.
Josef
Old Nov 18, 2015 | 01:23 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Was this canister replaced at some point? Maybe they forgot to reinstall the clamp. Lots of shady workmanship around.
Old Nov 18, 2015 | 08:03 AM
josefah's Avatar
josefah
I'm not sure honestly. Kinda irritating but I put the hose clamps on both ends last night. Checked my OBD and the permanent DTC was gone. Hopefully it stays gone.
Old Nov 18, 2015 | 08:22 AM
Bravo at's Avatar
Bravo at
FWIW, If not the hose clamp, then maybe the O-ring between the control valve and the canister.
Old Nov 21, 2015 | 03:10 AM
crookncastle's Avatar
crookncastle
errrrrr wrong. the missing clamp on the hose you are referring to is the vent control valve hose. the vent control valve hose does not need to be clamped because the other side of the hose is released to atmosphere.
Old Nov 21, 2015 | 11:47 AM
josefah's Avatar
josefah
Hmm.. I see. Curious that when I put the clamps on the permanent DTC code went away. Is there a common issue that happens with evap canisters causing them to leak? Or the check and purge valves?
Thank you.
Josef
Old Nov 21, 2015 | 02:39 PM
crookncastle
Thank you.
Josef
no dtc will ever go away on an obd2 car. it will be stored in the history of the pcm. did you mean the mil went off on the cluster? the mil will go off once the emissions tests are ran by the pcm and depending on the drive cycle the pcm will turn off the light because it no longer sees the problem and thinks the issue has been resolved. and there is no common issue with charcoal canisters, purge, or vent control valves going bad. sometimes its moron error where the driver overfuels and causes fuel to get into the canister which can cause problems with the vent valve. sometimes driver hits road debri and damages the canister.
Old Dec 26, 2023 | 10:51 PM
John3.7's Avatar
John3.7
P0456
What do I do to resolve this issue the code popped up a few days ago for me and I filled up 2 days ago and may have overfilled. Should I replace the vent control valve? Charcoal canister? Or purge valve?
Old Dec 27, 2023 | 12:11 AM
josefah's Avatar
josefah
if you just overfilled you can clear the error and it shouldn't come back. If it does come back you MAY need a smoke test to test for leaks.
In this case replacing the hose clamps on my EVAP canister fixed the issue. It's been eight years and 100k miles of driving. I'm still driving the car. it's passed the NC emissions test each year since.
No check engine lights. I'd start there.
Old Dec 28, 2023 | 11:05 AM
John3.7's Avatar
John3.7
P0456
Is that the only place it can leak from the evap canister valves, or the purge valve?
Josesoto96
General Tech Questions
Oct 24, 2023 03:24 PM
Conboss
Jul 13, 2020 04:27 PM
Cj3176
Jul 6, 2017 02:16 AM
350zrb
Jan 1, 2012 07:41 PM
hotwheelneil
67
Apr 7, 2009 02:32 PM
