P0106
Old Oct 22, 2015 | 10:14 PM
Upser88's Avatar
Upser88
P0106
Got this code again. I cleared the code and replaced the MAP sensor. Few hundred miles later cel. What else should I check not under warranty so might have to bite the bullet and take it to the dealer.
Old Oct 23, 2015 | 12:06 AM
35Sport's Avatar
35Sport
Do you have an aftermarket intake?
Old Oct 23, 2015 | 08:56 AM
qmantran's Avatar
qmantran
Doesn't the g37 use maf and not map sensors?
You have a vacuum leak
Old Oct 23, 2015 | 11:58 AM
SlateBlue G's Avatar
SlateBlue G
G's have 2 MAF's and 1 Map sensor in the intake manifold
Def check for vacuum leaks
Old Oct 23, 2015 | 12:36 PM
m3clubracer's Avatar
m3clubracer
ODBII = MAF and MAP sensor.
Old Oct 23, 2015 | 02:17 PM
qmantran's Avatar
qmantran
Don't understand what your trying to say.
Not all obd2 vehicles use both map and maf. Usually its one or the other.
Old Oct 23, 2015 | 02:34 PM
m3clubracer
True but in this case Nissan does.
Old Oct 25, 2015 | 04:15 PM
Upser88's Avatar
Upser88
Thnks for the help guys it was a leak
Old Oct 25, 2015 | 06:13 PM
m3clubracer
Where was it and how did you find it?
Old Oct 30, 2015 | 09:39 PM
Upser88's Avatar
Upser88
Couldnt find the leak does any anybody which hose I should check I sparked with carb n choke and the car still isles the same can't find it
Old Oct 31, 2015 | 07:47 AM
VIVID's Avatar
VIVID
Pyroclastic Flow
Upuser - So you didn't find the leak? I thought you had. Or is it: 'I know I have a leak, I just don't know where'? I'm subbed for a result to keep for any future issues on my G.
Sean
Ricio1991
Nov 6, 2015 09:52 AM
g35aa
Oct 26, 2015 05:45 PM
JakeG37
Oct 17, 2015 11:43 AM
Roblom
Oct 16, 2015 02:51 PM
GW330
Oct 16, 2015 02:29 PM
