SEDAN | Official Aggressive Offsets & FAT Tires
Old Dec 1, 2025 | 11:04 AM
  #496
projectpanda13's Avatar
projectpanda13
Originally Posted by the_hydroplan
мастер работ s1 19
work meister s1 19х9,5+30. spacer 5mm and RSR
ti2000
tires 225/45
beautiful. thanks for posting a rear quarter angle. I have that rear apron/lip and its great to have this as a reference.
Did you cut the bottom section of the bumper?
Old Dec 1, 2025 | 11:26 AM
  #497
the_hydroplan's Avatar
the_hydroplan
Yes, I cut it. Compared to a regular bumper, this one is just super
Old Dec 1, 2025 | 11:27 AM
  #498
Unequal length quad-tips... you don't see that every day. Very nice.
I'd like to see more of this car. Start a build thread or something.
Moscow as in Russia? Wow.
Old Dec 1, 2025 | 12:07 PM
  #499
the_hydroplan
Yes, bro, I'm from Russia. Am I the only one here?))
I'll post more photos later in the "Show off your sedans" section
In the meantime, I want to look up some information about the discs kansei tandem 19x9.5 +22 or 10.5 +22. I really liked them.
Old Mar 15, 2026 | 09:43 PM
  #500
gdirty.7's Avatar
gdirty.7
Need help deciding offset
Hey all, I have read through the entire forum. Just looking for opinions.
I am about to pick up some Advan Gt for my sedan, Rear specs are 20x10.5 ET45 with a 285/30. However for the front I am conflicted, I do have the akebono brakes so with that in mind I was going to go with a 20x9.5 ET35, with a 255/35. Is the offset too aggressive for the front? If so what would everyone recommend?
Thanks
Old Mar 15, 2026 | 11:14 PM
  #501
PNW_IPL's Avatar
PNW_IPL
Thanks
should be good. I ran 19x10.5 +22 upfront with a 265/35 firestone indy 500. I rolled a bit and some camber around -2.5 or so. I'd say a slight roll if needed. But should be ok
Old Apr 5, 2026 | 03:01 PM
  #502
the_hydroplan
мастер работы s1 19
Work Meister S1 19х9,5+30. Проставка 5 мм и шины RSR
Ti2000
225/45
Update for the 2026 season. Kansei Tandem 19x9.5 +22, tires 235/40
Old Today | 01:20 AM
  #503
gdirty.7's Avatar
gdirty.7
Hey, is anyone running 9.5 +35 up front?
Just looking to order wheels, I got some rears that are 20x1.5 offset 45 but, for the front I am not sure if the 9.5 will clear with a 255/35R20
Any help would be appreciated.
Old Today | 08:22 AM
  #504
projectpanda13
I think I responded to your Reddit post.
I am assuming its the same post.
20x9.5 +35 is a good spec up front and 255/30R20 will fit with no issues.
I would suggest 255/35R20 to pair better with your 285/30R20. I'd go a step further to actually recommend doing 245/35R20 which is even better of a pairing for the 285/30r20
Old Today | 08:24 AM
  #505
projectpanda13
Enkei PF01 18x10.5+38 255/40 and 285/35
I am currently running a 20mm spacer up front since the wheel hits the knuckle without it. I think I could have gotten away with a 15mm but 20mm was all I had and 7mm wasn't enough.
I also think if I use da taller tire like a 255/45r18, it would move the wheel upwards where the knuckle is narrower for more clearance and may not need a spacer.
Robert_K
Nov 6, 2023 02:55 PM
Hawaiian5
Apr 29, 2023 12:11 PM
JC-RH
Jan 19, 2014 12:37 PM
STOOF
Apr 16, 2011 05:04 PM
