Noob Question: Did I put my engine cover back on right?
Old Jul 20, 2015 | 05:30 PM
micafd3s's Avatar
micafd3s
not all Gs btw has resonators attached to their airbox... dont have any on my coupe..
Old Jul 20, 2015 | 11:57 PM
themrvin's Avatar
themrvin
Originally Posted by securityguy
What's a "grounding kit"?
Definitely worth it if you have an automatic! This post explains what it does exactly in the Q/A section.
https://www.myg37.com/forums/misc-ve...ing-wires.html
And this is the actual guide I followed:
https://www.myg37.com/forums/d-i-y-i...-your-own.html
It took me about an hr and a half to make the wires (while watching star wars, drinking a few beers, and taking my time) and maybe an hour for the actual install. Its pretty easy just take your time. I ended up paying about 65 bucks for all of my parts because I decided it would be a good time to invest in a heat gun and I also wire sleeved all my wires, soldered the terminals, and heatshrunk the terminals with the sleeves.
I got the wire sleeves from here (3/8"):
https://www.wirecare.com/products.asp?prodline=ptn
and the heatshrink tubing from there as well (5/8"):
https://www.wirecare.com/products.asp?prodline=h2
Let me know if you have more questions.
Quick update though: So I think its actually my air intakes that are causing the cover to not sit all the way down but im ok with it, think the tube housing part is slightly bigger than stock because thats the only place where it feels really snug.
Also I havent had much time to take the resonators out unfortunately. Its looking like its a little more involved and need to take the intakes off and maybe a few more pieces to have the proper room to work with. Hopefully this weekend.
Old Jul 22, 2015 | 10:20 PM
35Sport's Avatar
35Sport
Looks like you're missing the rubber seal that attaches to the oil filler neck and forms a seal on the under side of the cover. I found a pic online for reference.
Noob Question: Did I put my engine cover back on right?-mskzze8.jpg
Dillybar12
Oct 14, 2015 02:08 PM
Sway_NV
Sep 10, 2015 01:51 AM
Badgerman
Aug 19, 2015 02:26 PM
