Armrest Trim Removal
Old Mar 8, 2015 | 05:22 PM
tite_tite's Avatar
tite_tite
Hi,
Does anyone has any advice on removing the trim on front side of armrest?
Advice, solvent, etc. ?? Or do I have to manually peel??
Darn thing cut my finger the other day
Old Mar 8, 2015 | 11:01 PM
G37sPhoton's Avatar
G37sPhoton
Contemplating options for that piece as well, as I recently got a nice better than paper cut...hurts , as the cut is so fine. Anyway, I think once you pull, it just will pull away, but I didn't want to do that until I had a solution, so just careful now when reaching there, but will remove at some point , solution or not.
Old Mar 9, 2015 | 01:36 PM
tite_tite's Avatar
tite_tite
yup, bet you had blood running on your fingers.. & now you proceed w/ caution when going into your armrest box
Old Mar 9, 2015 | 05:31 PM
G37sPhoton's Avatar
G37sPhoton
damn straight! that cut hurt for some days after. anyway, i thought to glue it back down, but that looks messy and not sure if it will hold, so most likely will just remove it this weekend, just some tweezers and little time , as i don't have think it will make that much of a difference if its just black plastic...
Old Mar 10, 2015 | 10:12 PM
G37Xtreme's Avatar
G37Xtreme
That's replaceable under warranty of it still applies to you. I got mine replaced about 6 weeks ago.
Good old Infiniti. They don't offer just the trim piece, so the whole door must be replaced.
As long as it's on their dime...
Old Mar 11, 2015 | 05:30 PM
G37sPhoton's Avatar
G37sPhoton
yep barely in my range of warranty, so will be taking this bad boy and see what comes out of that- thanks for the info.
Old Mar 13, 2015 | 08:02 AM
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
yep correct...if under warranty they will replace it.....if not under warranty then yes that chrome layer will peel off.
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
Upscale Speed
Dec 26, 2015 08:45 AM
Upscale Speed
Dec 24, 2015 12:00 PM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
