How much Psi should i put in my tires?
Old Nov 14, 2014 | 09:49 PM
Lances Infiniti's Avatar
Lances Infiniti
I have a 2011 Infiniti g37 sedan with michilene premium sports tires stock size. I was wondering what would be the best psi to set my tires to for best launches on the street. I have lowered my car like a inch if that makes a difference. My friend said to do a little more psi in the back than the front. What do you guys think? Weather is around 40 degrees.
Old Nov 15, 2014 | 02:17 AM
PongSanity's Avatar
PongSanity
Read the manual.
Old Nov 15, 2014 | 08:50 AM
LexiG37's Avatar
LexiG37
Read PongSanity's post
Old Nov 15, 2014 | 09:05 AM
SwissCheeseHead's Avatar
SwissCheeseHead
lol. these posts.
Old Nov 15, 2014 | 10:26 AM
GS_G37S's Avatar
GS_G37S
Good info right here
Old Nov 15, 2014 | 11:51 AM
Butternut's Avatar
Butternut
I have stock size 225/50-18s on my xS anniversary stock wheels, my door sticker says 33 all around, and I run about 35 or 36 all around.
Old Nov 15, 2014 | 05:16 PM
G37sPhoton's Avatar
G37sPhoton
2011 sport and i run 34 in the summer and bump 1-2 in the winter month here in FL
Old Nov 16, 2014 | 07:04 AM
JT2014's Avatar
JT2014
Originally Posted by SwissCheeseHead
lol. these posts.
yes...helpful aren't they
The number in the manual & the door sill are the "recommended" pressure for best fuel economy & ride...
Your actual PSI should be adjusted for your weather/roads/tire brand/size & desired ride quailty. As long as you don't go over the max cold PSI stamped on the tire you can adjust them to whatever.
Start at the stock spec & try 5 psi above it...see if the car reacts better for you. Generally higher PSI will increase your road contact patch & enhance the performance of the car...but it may give up some fuel economy & increase ride harshness. Also be careful if you go too high you will have bad tire wear.
There is no magic PSI IMHO.You have to adjust for the factors I indicated & keep a schedule to check & adjust.
Old Nov 16, 2014 | 07:49 AM
blueis300's Avatar
blueis300
Good information. I thought it was lower psi for performance. Ive seen where people go to the track and they say to lower psi. Guess there is a difference from track and street? I have read to increase psi to improve mpg.
Old Nov 16, 2014 | 11:07 AM
Depends what kind of track~dragstrip or road coarse. Some get better drag times w/ lower psi.
Old Nov 16, 2014 | 03:12 PM
twin_snails's Avatar
twin_snails
Lowering PSI for increasing performance on the drag strip does not become a factor unless you're running very high horsepower and drag slicks. In our case for the street, it's more about the tire compound makeup than pressure. A softer compound will generally grip better and high-mileage harder compounds. Most of us here when we're going to the track are on standard radials. For our cars, you don't want the pressure too low because the rolling resistance increases as pressure decreases. That will definitely impact trap speed as well as your time.
In top fuel drag, the tire pressure is lower because it allows the tire to wrinkle up around the wheel. It absorbs some of the full force from the engine so the tires don't completely break loose and in essence functions a little bit like a second clutch.
Look at his video as an example:
Old Nov 16, 2014 | 03:41 PM
alfredo24pr's Avatar
alfredo24pr
It's actually the opposite. Higher pressure in the front to reduce rolling resistance, since this is a RWD car. On the rear, a lower pressure than the front is better but it should not be too low to create rolling resistance.
Summary:
Higher in the front (~32psi)
Lower in rear (~26-28psi)
This is just for the track launch. I haven't tried this, but will be testing it out next time at the track.
samuel1021
Nov 26, 2016 08:45 AM
Sway_NV
22
Aug 29, 2015 04:58 PM
G37xS-Life
Aug 27, 2015 10:34 AM
drkashifa
Aug 18, 2015 04:38 PM
goredcar
Aug 4, 2015 09:03 PM
