EX35 and Coupe sound so much better than Sedan??
Old 09-10-2014, 01:28 AM
conquistador
conquistador's Avatar
This is a total noob question and I'm sure it's just throatier mufflers on the two other vehicles... Few dumb questions:
1. Can I replace sedan mufflers for the coupe's or EX35's by simply welding them on?
2. Does the coupe have 1 muffler or 2?
3. Does EX35 have one muffler or 2?
4. Which exhaust set up gives a sedan an exhaust note similar to a Z?
I just can't stand the tame sound of the sedan
Old 09-10-2014, 03:37 AM
'11G37S
A 1/4 mile @ a time
'11G37S's Avatar
Well the coupe (Z &G) both have a single canister axle back (muffler) where the G sedan has two. That in addition to having less distance to travel through the pipes will give them a louder sound over the sedan.
In terms of putting the coupe exhaust on a sedan, anything can be done with the right budget, but I would venture to say it wouldn't be worth the time or the money. Just buy an aftermarket exhaust. If you're looking for something that sounds good but isn't loud I would recommend Fast Intentions with 18" resonators. Or even if you just swapped out your cats with Fast Intentions resonated high flow cars you should be just about there.
Hopefully this helped some.
Old 09-10-2014, 11:02 AM
GAWD
GAWD's Avatar
3. The EX and FX line also uses a single canister set-up like the G coupe. Two exhaust pipes enter the canisters backside, then the tail pipe exits either side. This wouldn't be ideal for trying to adapt into a sedan. I'm with '11G37S, aftermarket is best.
Old 09-10-2014, 11:51 AM
Baby Jumpman
Baby Jumpman's Avatar
You can do a muffler delete for the time being if you just want a little more volume similar to the coupe.
Old 09-10-2014, 01:38 PM
ANMVQ
ANMVQ's Avatar
No sir wont fit spare tire well is on the way. Been there did that. I had to split my canisters on my coupes exhaust to fit to my sedan
Old 09-10-2014, 05:46 PM
botlfed98
botlfed98's Avatar
i agree, couldn't believe how loud a stock FX was the other day as it drove past...
slowbird
08-03-2023 07:54 PM
Tunerz_Store
Brakes/Suspension
117
07-16-2018 02:04 PM
VQCrew
Intake and Exhaust
18
11-23-2015 08:30 PM
sedrick23
08-15-2015 05:41 AM
TakmaN
08-08-2015 07:47 PM
Quick Reply: EX35 and Coupe sound so much better than Sedan??
