eBay Grounding Kit
Well I just finished installing this grounding kit and am impressed! My car used to have a rough shift between 3rd and 4th in manual mode, but that is gone and all the other shift points are smoother and quicker. I ended up going off the diy thread with the wires instead of the directions with the aluminum block that came with the kit.
https://www.myg37.com/forums/d-i-y-i...-your-own.html
https://www.myg37.com/forums/d-i-y-i...g-kit-diy.html
https://www.myg37.com/forums/g37-cou...in-my-g37.html
Which one did you follow? I bookmarked three of them. This kit has all the right lengths to follow the DIY without using the block?
I like the copper wires with the silicone jacket on the ebay kit, but stay away from the anodized aluminum battery mount terminal block. Anodizing is bad for electrical conductivity and it seems they anodized right over where the wire terminals would screw into it. Plus its aluminum which means you're mixing aluminum and copper on top of the battery. Not a good idea. So far it seems the best way is to follow the diy and use the wires or make your own.
Gefartenblatz
Nov 10, 2015 11:45 AM
IrishMike
Sep 16, 2015 07:07 PM
