30K service yikes
Old Nov 12, 2014 | 10:10 AM
  #31
Eldan's Avatar
Eldan
The color of fluids means nothing, unless it's burnt.
Old Nov 12, 2014 | 11:12 AM
  #32
vqsmile's Avatar
vqsmile
exactly
Old Nov 12, 2014 | 11:26 AM
  #33
Originally Posted by vqsmile
Unless you have tracked the car and know that the tranny temps were high enough to burn the oil...
And the color of burnt gear oil is...?
I'm not disagreeing with you two, just asking for details.
Old Nov 12, 2014 | 12:25 PM
  #34
vqsmile's Avatar
vqsmile
It may or may not be extremely dark, but the most notable attribute will undoubtedly be the smell. Burnt gear oil smells, well . . . unmistakeable. Most all tranny/diff gear oils typically smell, but when they get burnt, it's just god awful.
Under normal conditions, the additives (like sulfur- pee-yoo!) contained in the oil will react with tiny particles of iron wearing off the gears and cause a harmless discoloration. When it all get cooked real good though, the smell becomes greatly intensified, to the point that once you smell it you'll likely not forget it, and whatever you do - do not spill the stuff anywhere that you don't want to be smelling it for the next few months.
Old Nov 12, 2014 | 04:36 PM
  #35
dkmura's Avatar
dkmura
20 Year Member
Normally, both gearbox lube or diff fluid will be a honey colored. The diff fluid does use pressure additives that smell like sulfur, but burned diff fluid will look darker, almost a black color, and you can smell a burnt quality to it.
fuzzed
Aug 21, 2020 09:35 AM
delfinparis
Nov 16, 2015 02:26 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
theKfactor
Sep 12, 2015 09:35 AM
