Anyone open up the stock mufflers and remove insulation?
Old Dec 26, 2013 | 09:55 PM
KCMO's Avatar
KCMO
Has anyone ever cut open the stock mufflers and removed any insulation, then welded them closed?
I'm looking for tanabe axle back level noise with no drone and from the mild reports about the tanabe, I thought this might work.
Old Dec 26, 2013 | 10:24 PM
35Sport's Avatar
35Sport
Remove the mufflers and have straight pipes welded in.
Old Dec 26, 2013 | 11:00 PM
KCMO's Avatar
KCMO
Did that on my '08, looking for something a little more subtle this time around.
I did this on my corvette and want to do something similar if possible
Decided to do the muffler mod on my Z06 (pics and video inside) - Corvette Forum
Just need to know what the inside of the muffler looks like if anyone has cut it open.
Old Dec 27, 2013 | 05:29 PM
Limited's Avatar
Limited
I've done it.
Inside of the mufflers look like this: (Although hopefully less rusted. mufflers purchased from a flooded G)
Old Dec 27, 2013 | 06:38 PM
KCMO's Avatar
KCMO
Did you leave the pipes alone and just remove the fiberglass packing? From the looks of that picture it looks like options for modifying the muffler may be limited.
Old Dec 27, 2013 | 07:23 PM
rm2342's Avatar
rm2342
What does it sound like? Rasp bag? or just slightly louder?
Old Dec 27, 2013 | 09:13 PM
Originally Posted by Limited
I've done it.
Damn, is that after you peeled off the starfish & barnacles
Old Dec 27, 2013 | 09:52 PM
Limited's Avatar
Limited
There isn't any fiberglass packing. I just removed the two walls you can see and left the pipes alone.
It was maybe a tiny bit louder than stock. But really difficult to notice the difference. I ended up doing the muffler delete but now i feel it can be too loud. I'm just difficult to please i guess
That's the muffler as soon as i got the shell off. Unmodified
Old Dec 28, 2013 | 04:07 PM
TheLocNar's Avatar
TheLocNar
Just get some resonators welded on with the straight pipes.
Old Dec 28, 2013 | 06:52 PM
STownSaint's Avatar
STownSaint
^have you done this?
That youtube clip of the G sedan with muffler delete sounds AMAZING, better than any clips with a/m exhaust systems.
Is there any downside to removing the mufflers, aside from possibly attracting unwanted attention?
Old Dec 28, 2013 | 08:22 PM
Limited's Avatar
Limited
STownSaint
Usually with mufflers removed you'll experience drone. I get a bit of drone at a little over 3k rpms which doesn't bother me as long as there is no drone on the highway. Plus the only time my car sees 3k+ rpms is when i want it to scream
Also, no mufflers means less back pressure which results in some low end power loss. I didn't notice any loss of low end power after removing my mufflers, but that's only according to my butt dyno.
Old Dec 28, 2013 | 09:47 PM
gsm026's Avatar
gsm026
Limited, not sure where you are from but here the highway speed limit is 75, and most people drive 80+. At that speed a 6MT is turning well over 3K.
Old Dec 29, 2013 | 01:16 AM
Limited's Avatar
Limited
I'm in WA. Highway speeds up near Seattle are 60mph. Most people drive around 65-70, plus i have a 7AT so i'm sure it's different than the 6MT.
Also there isn't any drone at over 3k rpms for me. It's just right at about 3,000-3,300 rpms. Anywhere past it sounds fantastic!
Old Dec 31, 2013 | 12:05 AM
STownSaint's Avatar
STownSaint
It's true that cruising at 75-85mph, I'm hovering around 3-3.5k rpm in 6th gear. Hmm, still far from modifying exhaust, but duly noted, Thanks sir
Old Dec 31, 2013 | 02:00 AM
Limited's Avatar
Limited
I actually just got back from a road trip to Canada and was cruising at about 80-85. Happy to say that there wasn't any drone at all near 3k rpms on the freeway. I even downshifted to 6th gear to get the rpms up a bit and it was fine. Although when i got under 2k rpms it did drone just a tad bit.
Conclusion from my muffler delete:
Some drone at about 3kish rpms city driving.
Only drones at under 2k rpms freeway.
Hope this helps more than my previous post.
slowbird
Aug 3, 2023 07:54 PM
Lt8Che
91
Apr 8, 2022 04:55 PM
Broski28
Feb 26, 2016 12:26 PM
BANNISTER
Dec 10, 2015 04:14 PM
SS2006
Aug 9, 2015 05:32 PM
