Sedan Chat Thread
Old Apr 29, 2024 | 07:13 PM
  #14641
STownSaint's Avatar
STownSaint
Originally Posted by Thedhc
Dont you got one in trunk?
Lift all four corners using the factory scissor lift? My back hurts just thinking about it
Old Apr 29, 2024 | 09:45 PM
  #14642
socketz67's Avatar
socketz67
Community Builder
Any of you guys ever swap out your thermostat for a new one, as preventative maintenance? I've had a vague opinion this is something you should do at 10 years or 100,000 miles. Now I'm no where near those miles, but the car is 13 years old. Do I bother?
I've been thinking of having the coolant system flushed & filled, and wondering if I should replace the old thermostat too.
I replaced mine back at 60K miles with an OEM one from Z1: https://www.z1motorsports.com/water-...c3352e20e55d5b
There is a post on here somewhere where I posted pics and discussed some of the things to watch out for when replacing (tough to get a good visual based on where it is located). Pretty straight forward job once the lower hose is off. Be careful to make sure that the gasket stays lined up when tightening down the new one. As you mentioned, for $30, it doesn't make sense not to replace it and even the radiator cap (if you have not already done so) when doing a coolant drain and fill.
Old May 7, 2024 | 02:27 PM
  #14643
rotarymike's Avatar
rotarymike
Moderator in Moderation
Re: heater hoses, just picked up the three hoses and 6 new clamps from the dealer. $200 - but $100 of it is the darn clamps. $17 per. Hoses are all 25-35 so in the long run not horrible.
Old May 11, 2024 | 10:50 AM
  #14644
STownSaint's Avatar
STownSaint
Seems like most accounts say the hoses are in fine condition, and it’s enough to replace just the plastic connector (with a metal one) and the two clamps which keep it in place.
Youre doing the hoses too just because you’ll be back there? Or found an issue with the hoses?
(going to place my order for parts soon, was only planning to buy the aftermarket connector and two OEM clamps)
Old May 11, 2024 | 11:02 AM
  #14645
and two OEM clamps)
No, get worm clamps! You won't be able to get the leverage you need to work with the OEM clamps.
Old May 12, 2024 | 10:50 AM
  #14646
STownSaint's Avatar
STownSaint
Copy that, prob saved me couple bucks too
For sizing, would 1/2-3/4” work or go up a size?
Old May 12, 2024 | 11:44 AM
  #14647
socketz67's Avatar
socketz67
Community Builder
If I recall correctly, I went up a size because 1/2-3/4" looked really small.
Old May 12, 2024 | 11:49 AM
  #14648
IDK about size. I just picked up a pack of 2 at Advance Auto, and brought one of the OEM clamps for size reference.
I bought the OEM clamps from Z1 when I bought the connector. So... you're welcome.
Old May 12, 2024 | 12:12 PM
  #14649
mummy2's Avatar
mummy2
Use oem clamps. All the experts recommend against worm clamps on hoses that expand due to heat. All you need is this.
Amazon Amazon
Old May 12, 2024 | 12:18 PM
  #14650
thescreensavers's Avatar
thescreensavers
The heater hose is 3/4 ID so yes buy the next size up.
Worm Gear clamps are fine as long as you tighten them appropriately and recheck after an oil change or two.
Old May 12, 2024 | 12:24 PM
  #14651
Originally Posted by mummy2
Use oem clamps. All the experts recommend against worm clamps on hoses that expand due to heat. All you need is this. https://www.amazon.com/Ziopetru-Clam...s%2C104&sr=8-4
That's a pretty cool tool. Sure, get that.
Old May 12, 2024 | 12:35 PM
  #14652
mummy2's Avatar
mummy2
i used worm clamps when I did mine and they leaked. Luckily I saved the 2 oem clamps and have been fine since.
Old May 12, 2024 | 02:00 PM
  #14653
socketz67's Avatar
socketz67
Community Builder
Not sure what happen. I changed mine in Feb 2023, and the pic above was taken this morning. No leaks or seepage. #knockonwood
Old May 12, 2024 | 02:40 PM
  #14654
mummy2's Avatar
mummy2
I've seen pics online where the worm clamps have tore into hoses as they have expanded so it gave me a reason to change back to the oem clamps, so I wasn't too mad. With that tool having a locking feature the switch out was a breeze.
Old May 12, 2024 | 04:33 PM
  #14655
socketz67's Avatar
socketz67
Community Builder
Don't get me wrong, I would never use them on the radiator hoses as we used to do that in the 80's and it was impossible to distribute the tension equally around the diameter of the hose and they always ended up leaking or requiring tightening.
They seem to work nicely on thicker hoses of much smaller diameter. Guess time will tell.
