Anyone know if the OEM G35, 350Z and/or 370Z shift ***** would fit a G sedan without any modifications?
From research it seems the G37 is cross-compatible with the 2009+ Nissan 370Z, but checking to see if anyone here has experience with the others. Thanks
After buying severe gear oil for my diff fluid changes, I am receiving emails now from Amsoil. Turns out, they have a cool feature on their page that you can make an account and add your vehicles to your garage. With this, you can input all service work you (or others) have done at what mileage, cost, what products (even if its not amsoil), etc. Thought this was pretty handy as I have just been keeping track on my phone for oil changes and whatnot. After inputting vehicle information, they will also have a product page that gives you info on what product they recommend for each service as well as capacities. I think this will be much easier for me to keep track of for my vehicles' (motorcycle included) services as they can send reminder emails as well as be able to print off all entered service work for when you sell the vehicle.
G35:
350Z:
Yes, it will fit with no problem. I had the 370Z ****, it was marginally thicker than the OEM Inifinit ****.I think most people don't like it because of the duplicate shift pattern.
Originally Posted by Corprin
Just put down a deposit on my next whip. G is getting detailed and tossed on the web for sale.
Many will say “why did you buy that!!?” But it’s been a long while since I’ve driven a car with so much giggle factor baked in.
Take delivery Wednesday of my pedestrian white VW Golf GTi Rabbit Edition manual.
G35:
350Z:
Yes, I'm almost 100% positive they will all work. I've also seen guys running the Maxima **** in their G's, but my preference is obviously for the GT R ****.
A year ago, I had a Southbend stage 2 clutch installed w/ CMAK, and I had them put in DOT4 fluid due to the higher boiling point. Fast forward to today and my clutch fluid is awfully dirty. The clutch doesn't feel quite as smooth, but no symptoms other than that.
I've read that if you're not driving hard regularly, then DOT4 fluid will become dirty quicker than DOT3 (not sure if that's true or not). I'm also wondering if a new clutch will cause the fluid to become dirty quicker than normal.
My question is, should I use DOT3 or DOT4 fluid for a daily-driven stage 2 clutch that isn't tracked? Thanks ahead.
FWIW, there's a TSB that recommends the G/Z 6MT use "GTR Brake Fluid" with the clutch, which is DOT4. Kind of pricey, tho.
Thanks, Rochester. I remember that TSB now. I think I'll keep with DOT4 since Infiniti and most forum members recommend it, but maybe get some regular ole' DOT4 for a fraction of the price.
So, I got a new garage door system and it turns out the home-link on the G is too old to work with most modern ones. Most of anything made after like 2012-2013. Nissan never updated the mirror on the G so none of them will work.
I found the solution was to get a mirror off a 2015 + Q50. Just did the swap today on mine and works great,same connector and mounting.
Unfortunately, the nose of my car sees an hour or two of direct sunlight per day, resulting in faded plastic mesh in the lower air dam. Anyone have experience bringing this plastic back to life? Heat gun trick work? Or any brand of that plastic restoration goop stand out as most effective?
Just for fun, try working in some Meguiar's Endurance Tire Gel. You can find it everywhere, even Walmart.
Maybe a decade ago, I discovered it works wonders with black plastic trim.
Try some Mother's Back-to-Black. It was the only thing that really worked to bring back the black in the door strip/moulding on my old E36 M3 and also worked great on out Jeep fenders when we still had plastic fenders on it.
I used to use Mother's Back-to-Black. But IMHO, Tire Gel works better and lasts longer.
I also use Tire Gel on the black plastics of my engine cover, and the radiator shroud... pieces like that. Rub it in and buff it out with a microfiber towel. You'll be shocked at how great it looks.
