Sedan Chat Thread
Old Apr 21, 2016 | 12:14 AM
  #10126
ZahyMatar's Avatar
ZahyMatar
People on the forum started calling the INFINITI emblem "Mt. Fuji" for as long as I can remember. Fuji, for short. AFAIK, those are the two interpretations: open road to the horizon, and Mt. Fuji. There's a third, less common interpretation, representing a missing slice of pizza.
And then there's the Pac-Man theory...
You've gotta see Mt.Fuji for yourself! It's freaking beautiful. (I'm on the right)
I still like to believe the Infiniti emblem represents Mt. Fuji though.
Old Apr 21, 2016 | 12:25 AM
  #10127
Gregor12's Avatar
Gregor12
Was this the guy??
Bro. I didn't know that you knew him too!!??
Old Apr 21, 2016 | 03:00 AM
  #10128
Gregor12's Avatar
Gregor12
So at the end of the day I put down 308rwhp and 250lb/ft and the car runs good and strong. Throttle response is a lot better and the car sounds completely different. Guess that's from the change in timing. Shift points are a little harder and now I have valet mode, not that I'll ever use it lmao. Comparing to my 370z tuned via uprev, ecutek is better for sure. Highly recommend it. Unfortunately I didn't pick up as much as I thought I would with the intakes and tune. But I put down 6 more hp in hotter weather compared to a 2011 g37 sedan with FI CBE, HFC, and z1 intakes. So maybe my hopes were too high lol. What do you guys think about the numbers? Here are some pics.
Old Apr 21, 2016 | 06:57 AM
  #10129
Lego_Maniac's Avatar
Lego_Maniac
Nice numbers.
I didn't realize you were local. Any particular reason you chose Soho over Motion Lab? Nice to know I have multiple options should I ever decide to get tuned or want someone to do an install for me.
Old Apr 21, 2016 | 07:51 AM
  #10130
ZahyMatar's Avatar
ZahyMatar
Nice numbers.
RZG Motorsports in New Bern is another place. Really small shop, but the guy that works there is very knowledgeable when it comes to the VQ platform. His FI 350z builds are impressive.
Old Apr 21, 2016 | 12:33 PM
  #10131
Gregor12's Avatar
Gregor12
Nice numbers.
What's up man. Good to know there is another local number!! I'll shoot you a pm haha
Old Apr 21, 2016 | 12:54 PM
  #10132
Gregor12's Avatar
Gregor12
I've heard good things about them too. I think soho is the best in our area when it comes VQ's though. After driving their 350z with their turbo kit I'm buying a salvaged 350 to boost and gut. Their kit made 400/400 on 6.5psi 😂😂😂 and the power is instant. It almost feels like it's NA. For a reference. A kinetix kit at 10 lbs made 372 on the same Dyno and the momentum kit makes around 400 on 11 lbs. and nikes been tracking and beating the **** of that Z for 6 years and it's still running like a champ lol so he's not running a lot of timing or anything else to compensate for boost. It's just an extremely efficient kit and a Garrett turbo.
Old Apr 21, 2016 | 07:09 PM
  #10133
SonicVQ's Avatar
SonicVQ
The dyno shows two runs... is that two runs back to back?
You should ask them to email you the runfiles and then use the WinPep Dyno Run Viewer
(http://www.powercommander.com/downlo...2_Install_.zip)
to plot your before and after graphs and further analyze your dynos.
It looks like your tune (or more accurately a re-calibration) has leaned the AFR to high 12s, low 13s at WOT.
Stock (at least on my car) is low 12s. The leaner mixture results in a little more power.
Thanks for posting your dyno!
Old Apr 21, 2016 | 10:06 PM
  #10134
Gregor12's Avatar
Gregor12
Low twelves are sill fairly rich for NA. 12.8 seems to be the target number for the best a/f ratio when considering HP.
As for the graph, that's not my before and after. This was copied from the original post:
**I put down 6 more hp in hotter weather compared to a 2011 g37 sedan with FI CBE, HFC, and z1 intakes. ***
Old Apr 22, 2016 | 11:20 AM
  #10135
Nico-derm's Avatar
Nico-derm
Decent numbers but tough to compare numbers with different variables... another 3 weeks til my fast intentions order comes in and I am growing impatient lol. Have other parts waiting so I only book the lift one weekend.
2.25" CBE / 18" inline / RHFC
Hotchkis Sways F/R
Stillen Crank Pulley/Belt
Red Grounding Kit
RJM CPA
Can't decide on coil brand.. need summers/rims but it's tough to choose an offset without knowing the drop
Old Apr 22, 2016 | 11:29 AM
  #10136
Wow. That's a busy weekend. Have you put any time estimates on all that?
I'll take a whack, with numbers pulled out of thin air...
Sways... 2 hours
Cats... 4 hours of abject frustration
Catback... 2 hours
Crank Pulley... 3 hours
RJM pedal... 4 hours
Grounding kit... 1 hours
Old Apr 22, 2016 | 11:37 AM
  #10137
ColumbiaSkinny's Avatar
ColumbiaSkinny
Holy sheep ****. Is the crank pulley swap really a 3 hour job? What makes it so time consuming?
Old Apr 22, 2016 | 11:38 AM
  #10138
I did say "pulled out of thin air"
But I've not had it done on my car, and never will, so that was a total guess. The other numbers feel right, don't you think?
Old Apr 22, 2016 | 11:42 AM
  #10139
MaQG37's Avatar
MaQG37
I think the cats ,catback, and RJM are a little off. He has a 13' so there is a good chance the cats can be done quickly; My cats were done in less than an hour. The catback can be done easily in an hour as well. If he has the RJM v3, it takes a good chunk of time away with the pre-assembly.
Old Apr 22, 2016 | 11:47 AM
  #10140
ColumbiaSkinny
lol, yeah you did, my bad.
And yeah on the other jobs. Always best to round up which it looks like you did.
JMO but i think the crank pulley swap would have a better/bigger impact on the 7AT than the 6MT. Not that it wouldn't benefit the MT.
I did the 3 piece pulley swap on my Mustang, crank, water pump, and alternator, and it was a solid mod. Noticed much better throttle response but honestly couldn't tell you if it helped in the HP/TQ department....
